POST request fails. Getting data missing required value
by AmitParmar on Thu Nov 21, 2019 6:14 am
I am trying to send HTTP POST request to adafruit IO from my ESP32 TTGO T Call. But some how request fails and returning error code 422. Below is my code and complete error details.
Error:
HTTP/1.1 422 Unprocessable Entity
"error":"request failed - Record invalid. Failed to save data to feeds/temprature, data missing required value"
      String httpRequestData = "[{\"value1\":\"123\"}]";
      client.print(String("POST ") + resource + " HTTP/1.1\r\n");
      client.print(String("Host: ") + server + "\r\n");
      client.println("Connection: close");
      client.println("Content-Type: application/json");
      client.println("Authorization: key=my authorization key");
      client.print("Content-Length: ");
      client.println(httpRequestData.length());
      client.println();
      client.println(httpRequestData);
Same request works when i try to send request through Fiddler tool.
Can somebody please help me resolve my issue?
Thanks In Advance,
Amit
AmitParmar
Re: POST request fails. Getting data missing required value
by abachman on Thu Nov 21, 2019 12:43 pm
Hi Amit,
You're wrapping the JSON object ("{ }" symbols) in an array ("[]" symbols), which is not necessary. You're also using the key, "value1" when IO expects the key to be "value".
Also, different API endpoints use different payload formats. For example, the "Create Data" endpoint looks different from the "Create Data in a Group" endpoint (not well documented).
What value are you using for `resource` in this example? How does `httpRequestData` compare to what you're sending from Fiddler? Is it exactly the same format or is Fiddler handling JSON generation? Is it possible to see a screenshot or print out of your Fiddler setup with the API Key hidden?
- adam b.
abachman
by AmitParmar on Fri Nov 22, 2019 6:39 am
HI Adam,
That worked!!! :)
Thank you so much for quickly catching the issue. As you mentioned, I removed square bracket and changed value1 to value which solved my problem. Thanks again.
i.e.
"{\"datum\": {\"value\": \"15\"}}
I have one more question.
Now, I want to send push notification to my android app as soon as new data has been added to the database. Is it possible with Adafruit io? Can you please point me out any online document if available?
Amit
AmitParmar
