Adafruit IO without Libraries!
by MotazBanyAmer on Fri Nov 22, 2019 11:33 am
I'm trying to use Adafruit IO without Libraries, Just using AT Commands of my SIM808 module through GPRS.
I saw this is applicable to ThingSpeak, but couldn't do it with Adafruit IO.
the reason I don't want to use libraries is that I'm just building a prototype with Arduino, and Later I most likely to use ARM Controller, and I don't want to be stuck with Arduino libraries.
I looked into the resources, it's really confusing, I saw the method of creating a feed, it's available with cURL, and Arduino libraries. but I was not able to understand how to do it without the libraries.
thank you in advance
MotazBanyAmer
Re: Adafruit IO without Libraries!
by abachman on Fri Nov 22, 2019 4:17 pm
Hi Motaz,
Are you looking for a guide to generating HTTP requests from scratch? What level of detail would be helpful?
- adam b.
abachman
by MotazBanyAmer on Sat Nov 23, 2019 4:20 pm
Yeah exactly
Actully would be great if you could give me detaild nerdy resources for the whole process :D
but would be good too if I had sufficient guide for doing the request from GPRS (im using SIM 808) with bare AT commands.
And thank you for your help sir
MotazBanyAmer
by abachman on Mon Nov 25, 2019 3:08 pm
Ah, hmm. If you haven't written raw HTTP requests from a bare TCP socket before, using any library is strongly recommended. If the Adafruit IO library works, use that for prototyping and switch to raw HTTP when you need to cross that bridge. Also, if you found a guide to publishing data to ThingSpeak "without any libraries", you should be able to use the same code to publish to IO with only minor changes. Do you happen to have a link to that guide?
IO will work with HTTP 1.0 requests and needs at least the Host, Content-Type, Content-Length, and X-AIO-Key headers. For example, this is a valid and complete HTTP request:
POST /api/v2/test_username/feeds/my-sample-feed/data HTTP/1.0
Host: io.adafruit.com
Content-Type: application/json
Content-Length: 15
X-AIO-Key: b780002b85d6411ca0ad9f9c60195f72
{"value":"123"}
Note, because it's HTTP, each of those newlines must be \r\n instead of \n. The Content-Length of 15 is the length of the body of the request, {"value":"123"}, not including the newlines.
This is a complete and valid Ruby program that generates and sends a request on a raw TCP socket:
require 'socket'
require 'json'
client = TCPSocket.new 'io.adafruit.com', 80
io_username = 'a_real_account'
io_key = 'totallyfakekey19'
io_feed = 'temperature'
data = {
  value: "80.30"
body = JSON.generate(data)
request =  "POST /api/v2/#{io_username}/feeds/#{io_feed}/data HTTP/1.0\r\n"
request += "Host: io.adafruit.com\r\n"
request += "Content-Type: application/json\r\n"
request += "Content-Length: #{body.size}\r\n"
request += "X-AIO-Key: #{io_key}\r\n\r\n"
request += body
request += "\r\n\r\n"
client.print request
client.close_write
while line = client.read
  puts line
  break if line.empty?
end
I'm not familiar with writing code for a cellular device. You'll have to look up your device's documentation for opening and writing bytes to TCP sockets.
- adam b.
abachman
