MQTT ERROR: rejected, not a valid topic format
by rum_01 on Sat Nov 30, 2019 3:20 pm
I`m new to Adafruit IO.
When I try to subscribe MQTT to my Topic, the Adafruit IO Portal shows the Error "MQTT ERROR: rejected, not a valid topic format"
What`s wrong.
I have a ESP8266 and Platform.io using the Example "mqtt_esp8266_callback"
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
rum_01
Re: MQTT ERROR: rejected, not a valid topic format
by brubell on Mon Dec 02, 2019 11:22 am
Hi rum_01,
Could you post your complete code below so I can assist you with debugging?
brubell
by rum_01 on Tue Dec 03, 2019 5:14 pm
OK. I did some more Debugging.... and found the problem.
I also used another libary for NTP time sync. I defined the following:
WiFiUDP ntpUDP;
NTPClient timeClient(ntpUDP, "europe.pool.ntp.org", 3600, 60000);
Don`t know exactly where the problem is... but after removing the definition the subscription for the MQTT IO Adafruit works.
rum_01
by brubell on Tue Dec 03, 2019 5:28 pm
Interesting, thanks for the update and report. I haven't seen this before on the forums. There might be a chance that your device's time wasn't syncing with the Adafruit IO MQTT broker's (server) time.
brubell
by mkraats on Sun Jan 05, 2020 5:17 pm
I have exactly the same problem with some old code that I dusted off and now isn't working :-) :
MQTT ERROR: aedes_DoWSYkpeP_dI ***.***.***.*** PUBLISH to topic `myuserfeedname` rejected, topic is not a recognized format
I am not using ntp currently in this sketch and WiFiUDP.h also shouldn't be an issue ( it's in the WiFi library for the ESP ). I'm using this with a D1 mini, updated AdaFruitIO library.
mkraats
by mkraats on Mon Jan 06, 2020 9:22 am
Ah, one should always be careful after dusting off old code. Apparently, I had used:
#define AIO_MYFEED "myfeedname"
But now, only:
#define AIO_PM25 "/feeds/groupname.feedname"
Seems to work.
mkraats
