Home automation using google assistant and node mcu
by MohanKrishna on Wed Dec 04, 2019 3:44 pm
Hello sir,
We are doing a project on Home automation with nodemcu board.we have query
on your adafruit website regarding the "AIO KEY".while we write code in
arduino c++ we use that specific AIO KEY.our doubt is we have to 2 more keys
of different users in that code is it possible and also on what basis AIO
KEY is being generated how it will state the uniqueness of user.please tell
us sir it will use to our project work
MohanKrishna
Re: Home automation using google assistant and node mcu
by brubell on Thu Dec 05, 2019 10:58 am
You may want to consider using shared feeds instead. This will let you access another user's feed, but your sketch will use only one account key.
For information about Shared Feeds, check out the Learning System Guide: https://learn.adafruit.com/adafruit-io- ... ing-a-feed
The Adafruit IO API Key is unique per-account. There's also a system-generated, URL-safe identifier for each feed you're writing to (see Naming Feeds in Adafruit IO: https://io.adafruit.com/blog/tips/2016/ ... ing-feeds/).
brubell
