Secure IoT connection
by flounder on Wed Dec 11, 2019 11:45 pm
RING recently got in trouble because they were sending passwords to the local AP in plaintext. So I watched Lady Ada's talk about secure IoT. Lots of good things said, but nothing specific about how to go about this, particularly with reference to Adafruit WiFi products. For example, does the ESP32 WiFi library send the password (and even SSID) encrypted using WPA/WPA2 or does it send it in plaintext? I went to the github espressif/arduino-esp32 WiFi library, and there is no documentation. I do not find it productive to read unfamiliar code to reverse-engineer how it works. So advice on how to be sure I am not making the same mistake RING made is valuable.
joe
flounder
Re: Secure IoT connection
by brubell on Wed Dec 18, 2019 5:19 pm
Hi flounder,
The Adafruit IO Arduino library uses the WiFiClientSecure (https://github.com/adafruit/Adafruit_IO ... 32.cpp#L20) class from arduino-esp32 (https://github.com/espressif/arduino-es ... ientSecure). This class is used to establish a secure connection using TLS (SSL) between the Adafruit IO Server (verified by its fingerprint https://github.com/adafruit/Adafruit_IO ... ions.h#L83) and the ESP32 "client". After the connection is established, all data transferred between the AP and the ESP32 is encrypted.
- brent r.
brubell
