Python client can't access feed by name
by fruity_pebbles on Fri Dec 13, 2019 3:53 pm
I don't seem to be able to access my feed by name. The feed is named "pi0_1_temperature" and its key is "pi0-1-temperature". I create a Client instance, then do
tf = client.feeds(feed_name)
which results in this error:
  File "<stdin>", line 1, in <module>
  File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 274, in feeds
    return Feed.from_dict(self._get(path))
  File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 118, in _get
    self._handle_error(response)
  File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 108, in _handle_error
    raise RequestError(response)
Adafruit_IO.errors.RequestError: Adafruit IO request failed: 404 Not Found - not found - that is an invalid URL, please check the API documentation at https://io.adafruit.com/api/docs to make sure your URL is correct
Using the key instead of the name works OK.
The documentation says that I can use name or ID or key, but that doesn't seem to be the case.
fruity_pebbles
Re: Python client can't access feed by name
by brubell on Wed Dec 18, 2019 5:11 pm
Where in the Adafruit IO Documentation is this located so I can remove it?
You should always use feed keys when referring to an Adafruit IO Feed in Adafruit IO Python
- brent r.
brubell
by fruity_pebbles on Wed Dec 18, 2019 7:48 pm
It looks like there are a few mistakes on this page: https://adafruit-io-python-client.readt ... feeds.html
The examples for Feed Retrieval show only a key argument for Client(), whereas the example for Feed Deletion correctly shows username and key arguments for Client().
The text for Feed Retrieval includes this statement: "Alternatively you can retrieve the metadata for a single feed by calling feeds(feed) and passing the name, ID, or key of a feed to retrieve". This is what led me astray.
Given that you can only access a feed by key the convention used in a few of the examples seems misleading. The Send Data example has this:
test = aio.feeds('test')
aio.send_data(test.key, 98.6)
To me that implies that 'test' isn't necessarily the feed's key, otherwise why would you bother calling feeds('test') and then using test.key on the next line.
fruity_pebbles
