MQTT API - how to change 'qos'
by readylan on Mon Dec 16, 2019 2:04 pm
I'm exploring how to set the parameter 'qos' (for quality of service) in my mqtt client connection with python.
In online documentation you can read Adafruit IO can deal with values 0 & 1 for that. How can I set qos=1 in code?
This is the signature of publish with Adafruit IO Client Library (mqtt)
mqttc.publish(feed_id, value, group_id, feed_user)
Thanks in advance,
Eduardo
readylan
Re: MQTT API - how to change 'qos'
by brubell on Wed Dec 18, 2019 4:52 pm
Hi readylan,
Yes, MQTT QoS 0 and QoS 1 are supported by Adafruit IO. QoS 2 is not.
To help me debug the signature you provided better, I need to know which library are you using to publish data (URL link or a name please)
- brent r.
brubell
by readylan on Thu Dec 19, 2019 6:32 am
Hello brubell, thanks for your reply,
I'm using recent Adafruit libraries, this is my virtualenv (python 3.6.9):
$ pip freeze
adafruit-io==2.3.2
certifi==2019.11.28
cffi==1.13.2
chardet==3.0.4
cryptography==2.8
future==0.18.2
idna==2.8
paho-mqtt==1.5.0
pkg-resources==0.0.0
pycparser==2.19
python-telegram-bot==12.2.0
requests==2.22.0
six==1.13.0
tornado==6.0.3
urllib3==1.25.7
Now, in code, I have instantiated mqtt client object this way:
from Adafruit_IO import MQTTClient
mqttc = MQTTClient(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
After that, how can I set QoS for publish / subscribe actions ?
Eduardo
readylan
by brubell on Thu Dec 19, 2019 11:29 am
Ok, I am mistaken. You are not able to set this in Adafruit IO Python...yet. I added an issue to the GitHub repository (https://github.com/adafruit/Adafruit_IO ... issues/106) for this library and will patch it. Thanks for bringing this up.
- brent r.
brubell
by brubell on Mon Dec 23, 2019 2:48 pm
Updating this thread with good news
Adafruit IO Python v2.4.0 adds QoS Levels to subscribe calls!
https://github.com/adafruit/Adafruit_IO ... /tag/2.4.0
To subscribe to an Adafruit Feed with a provided QoS Level (1, in this example) with Adafruit IO Python v2.4.0 or above, use the following method call:
    client.subscribe(feed_identifier, qos=1)
brubell
by readylan on Sat Dec 28, 2019 8:48 am
Hello!
I wonder how to try this improvement since I don't know how to set qos 1 for a PUBLISH command. I suppose the addition of the qos parameter in the client's publish method is work in progress ;)
In fact, I see that the messages sent with qos 1 are returned by the broker with qos 0:
(In this log I used the mosquitto client of my machine with Linux ubuntu)
This code is showing the publish action with QoS 1 ( -q 1):
mosquitto_pub -h io.adafruit.com -u readylan -P *** -q 1 -t readylan/feeds/kk -m 2 -d
Client mosq-TDrBZShLUysQaoaKma sending CONNECT
Client mosq-TDrBZShLUysQaoaKma received CONNACK (0)
Client mosq-TDrBZShLUysQaoaKma sending PUBLISH (d0, q1, r0, m1, 'readylan/feeds/kk', ... (1 bytes))
Client mosq-TDrBZShLUysQaoaKma received PUBACK (Mid: 1, RC:0)
Client mosq-TDrBZShLUysQaoaKma sending DISCONNECT
Here, the subscribe action with QoS 1 ( -q 1):
mosquitto_sub -h io.adafruit.com -u readylan -P *** -q 1 -t readylan/feeds/kk -d
Client mosq-Yy35PAZhNezDlK4cVw sending CONNECT
Client mosq-Yy35PAZhNezDlK4cVw received CONNACK (0)
Client mosq-Yy35PAZhNezDlK4cVw sending SUBSCRIBE (Mid: 1, Topic: readylan/feeds/kk, QoS: 1, Options: 0x00)
Client mosq-Yy35PAZhNezDlK4cVw received SUBACK
Subscribed (mid: 1): 1
Client mosq-Yy35PAZhNezDlK4cVw received PUBLISH (d0, q0, r0, m0, 'readylan/feeds/kk', ... (1 bytes))
2
Note that the response received does not maintain the initial Quality of Service.
Best regards,
Eduardo
readylan
by brubell on Thu Jan 02, 2020 3:49 pm
Hi readylan,
We do not support publishing with a QoS level, only subscribing.
brubell
