io.adafruit DashBoard
by plcchile on Thu Dec 26, 2019 12:26 pm
Hi Friends:
I have done a project on DashBoard that works properly, the question is the following it is posible for a user to be able
to see dashboard but without being able to change the configuration.
Best Regards PlcChile
plcchile
Re: io.adafruit DashBoard
by brubell on Fri Dec 27, 2019 10:07 am
Hi PlcChile,
You'd want to make your Adafruit IO Dashboard public.
Though, unlike the process of sharing a feed, Adafruit IO does not have the ability to selectively-allow certain Adafruit IO accounts from viewing your Dashboard. This means that when you publicize your dashboard, you are publicizing it to everybody with both the link and an Adafruit IO account. When sharing a dashboard with others, be careful of whom you share the link with.
They will not be able to change the configuration of your dashboard. The blocks (and the dashboard layout) are static and belong to the dashboard creator. The person you share the dashboard with will not be able to modify it by moving, resizing, or adding blocks.
See this learning system guide page for more information and instructions to share your dashboard: https://learn.adafruit.com/adafruit-io- ... -dashboard
brubell
