Minimqtt on windows
Minimqtt on windows
by baxtertidwell on Sat Dec 28, 2019 11:47 am
I'd like to install adafruit-circuitpython-minimqtt on Windows using PIP3. I know it's for circuitpython, but pip-ping it will allow VSCode to expose the objects to intellisense, which makes programming soooo much easier.
But it can't find a version:
C:\WINDOWS\system32>pip3 install adafruit-circuitpython-minimqtt
ERROR: Could not find a version that satisfies the requirement adafruit-circuitpython-minimqtt (from versions: none)
ERROR: No matching distribution found for adafruit-circuitpython-minimqtt
Same problem with adafruit-circuitpython-ntp.
Is there a direct link, or perhaps a library lookup I need to modify on Windows?
I'm able to install adafruit-io, so it must be in some library that Windows can see.
baxtertidwell
Re: Minimqtt on windows
by brubell on Thu Jan 02, 2020 2:56 pm
Thanks for the info - we've identified some of these libraries missing from PyPi and are working on adding the libraries to PyPi.
I will bump this thread when they're up.
- brent r.
brubell
