Time Service
Time Service
by davegun on Sat Jan 04, 2020 2:16 pm
I'm trying to understand how the Time Service works. I found https://io.adafruit.com/username/services/time. I also found the example "adafruitio_17_time_subscribe".
Using the information from https://io.adafruit.com/username/services/time: When I enter https://io.adafruit.com//api/v2/time/ISO-8601 , I get the time as expected.
I would now like to get the current time in my time zone. The instructions for /integrations HTTP API say:
GET /api/v2/:username/integrations/time
Parameters:
tz [OPTIONAL] Timezone to get the current time for.
My time zone is "America/Chicago", so what do I type into my browser to get a proper response?
My goal is to modify the example "adafruitio_17_time_subscribe" sketch to print the time with time zone offset. Once I figure this out, I should be able to use it in my project sketch.
davegun
Re: Time Service
by brubell on Mon Jan 06, 2020 11:47 am
tz should be included in the body of the HTTP request. You will not be able to do this via your browser's URL bar, you'll need a tool such as CURL.
Here's an example of the request for obtaining ISO-8601 with USA East Coast time:
curl -X GET -d 'tz: US' -v -i 'https://io.adafruit.com//api/v2/time/ISO-8601'
Here's a website which let's you try out API requests from your browser, I already set it up to mimic the CURL example above:
http://apirequest.io/5e1352db9fdf4a065f ... ST5kyHQqJg
Adafruit IO Arduino uses the MQTT API, not the HTTP API. Unfortunately, that API does not allow you to pass in a configurable timezone (MQTT is a bit restrictive in this sense) and you will need to obtain the time, and perform timezone calculations inside the code which runs on your device
- brent r.
brubell
Re: Time Service
by davegun on Sat Jan 11, 2020 5:03 pm
Bent,
That helped, thanks!
davegun
