Programming for similar feeds
by john87 on Sun Jan 05, 2020 3:16 pm
I think my app may be similar to XovorIoT's; I have a few devices, e.g. Huzzah Feathers reporting temperature and humidity. I'd like to call them "Indoor", "Outdoor", and "Greenhouse".
Now, I'm keeping separate ino files for each, with lines like:
AdafruitIO_Feed *t_out = io.feed("t_out");
t_out->save(Temps[1]);
I'd like to make one change in the file, for example to change all of the instances of t_out to t_tgreenhouse. I suppose I can use a variable for the io.feed(location) but is there a way to handle the code at the other positions.
John
john87
Re: Programming for similar feeds
by brubell on Mon Jan 06, 2020 11:34 am
Totally valid way of doing it, it'll work.
I thought about an alternative for you, too. I'd go about it by making a "template" .ino file which contains t_greenhouse, t_out, etc. This would reduce the amount of changes you'd need to make as you'll only be modifying/compiling/uploading one .ino file.
At the top of the file, I'd create #define's for your nodes like:
//types of sensor nodes, uncomment if used:
#define GREENHOUSE
// #define OUTDOORS
// #define INDOORS
In the code, I'd add a pre-processor conditional like:
#ifdef GREENHOUSE:
 AdafruitIO_Feed *t_out = io.feed("t_greenhouse");
#elif OUTDOORS:
The idea is - your code would only reference t_out, but the value of t_out would changed based on how you set your definition (#DEFINE)
- brent r.
brubell
