THROTTLE WARNING
THROTTLE WARNING
by Nimbleq on Mon Jan 13, 2020 5:24 am
I am getting a Warning sms again and again : Throttle warning nimbleq data rate limit reached , 7 seconds until throttle released.
I am using following codes.
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
int sensor = D1;// we will use an digital sensor
/************************* WiFi Access Point *********************************/
#define WLAN_SSID       "XT"
#define WLAN_PASS       ""
/************************* Adafruit.io Setup *********************************/
#define ARB_SERVER      "io.adafruit.com"
#define ARB_SERVERPORT  1883                  // use 8883 for SSL
#define ARB_USERNAME    ""
#define ARB_PW         ""
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// or... use WiFiFlientSecure for SSL
//WiFiClientSecure client;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, ARB_SERVER, ARB_SERVERPORT, ARB_USERNAME, ARB_PW);
/****************************** Feeds ***************************************/
// Setup a feed called 'arb_packet' for publishing.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
#define ARB_FEED "Nimbleq/feeds/Fan"
Adafruit_MQTT_Publish ap = Adafruit_MQTT_Publish(&mqtt, ARB_FEED);
// Arbitrary Payload
// Union allows for easier interaction of members in struct form with easy publishing
// of "raw" bytes
typedef union{
    //Customize struct with whatever variables/types you like.
    struct __attribute__((__packed__)){  // packed to eliminate padding for easier parsing.
        char charAry[10];
        int16_t val1;
        unsigned long val2;
        uint16_t val3;
    }s;
    uint8_t raw[sizeof(s)];                    // For publishing
        // Alternate Option with anonymous struct, but manual byte count:
            char charAry[10];       // 10 x 1 byte  =   10 bytes
            int16_t val1;           // 1 x  2 bytes =   2 bytes
            unsigned long val2;     // 1 x  4 bytes =   4 bytes
            uint16_t val3;          // 1 x  2 bytes =   2 bytes
                                            TOTAL =    18 bytes
        uint8_t raw[18];                    // For publishing
} packet_t;
/*************************** Sketch Code ************************************/
// Bug workaround for Arduino 1.6.6, it seems to need a function declaration
// for some reason (only affects ESP8266, likely an arduino-builder bug).
void MQTT_connect();
  Serial.begin(115200);
  delay(10);
  pinMode(D1,INPUT);
  Serial.println(F("Adafruit MQTT demo"));
  // Connect to WiFi access point.
  Serial.println(); Serial.println();
  Serial.print(F("Connecting to "));
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(F("."));
  Serial.println();
  Serial.println(F("WiFi connected"));
  Serial.println(F("IP address: ")); Serial.println(WiFi.localIP());
packet_t arbPac;
const char strVal[] PROGMEM = "Hello!";
  // Ensure the connection to the MQTT server is alive (this will make the first
  // connection and automatically reconnect when disconnected).  See the MQTT_connect
  // function definition further below.
  MQTT_connect();
  //Update arbitrary packet values
  strcpy_P(arbPac.s.charAry, strVal);
  arbPac.s.val1 = -4533;
  arbPac.s.val2 = millis();
  arbPac.s.val3 = 3354;
   // Alternate Union with anonymous struct
   // (see union declaration above)
     strcpy_P(arbPac.charAry, strVal);
     arbPac.val1 = -4533;
     arbPac.val2 = millis();
     arbPac.val3 = 3354;
int value = digitalRead(sensor);
int cvalue = 1-value;
Serial.println(cvalue);
delay(10);
  if (! ap.publish(cvalue))
        Serial.println(F("Publish Failed."));
        delay(500);
      else {
        Serial.println(F("Publish Success!"));
        delay(500);
      delay(2000);// it should be proper otherwise if less than needed than
      //THROTTLE WARNING: user name data rate limit reached, 15 seconds until throttle released kind of sms will be seen and after few secxonds project will be closed by adafruit
  // ping the server to keep the mqtt connection alive
  // NOT required if you are publishing once every KEEPALIVE seconds
  if(! mqtt.ping()) {
    mqtt.disconnect();
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print(F("Connecting to MQTT... "));
  uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
       Serial.println(mqtt.connectErrorString(ret));
       Serial.println(F("Retrying MQTT connection in 5 seconds..."));
       mqtt.disconnect();
       delay(5000);  // wait 5 seconds
       retries--;
       if (retries == 0) {
         // basically die and wait for WDT to reset me
         while (1);
  Serial.println(F("MQTT Connected!"));
Nimbleq
Re: THROTTLE WARNING
by brubell on Mon Jan 13, 2020 10:42 am
Your loop is sending new data to Adafruit IO every 2.51 seconds. So, 23.90 data points/min.
Adafruit IO's free tier has a data rate of 30 data points per minute, you shouldn't be seeing that warning.
Could you run your sketch again with this page open (http://io.adafruit.com/monitor). Please screenshot the page, make sure it shows the Live Data and Live Errors sections. This'll help me diagnose exactly what the issue is.
Thanks,
Brent R.
brubell
