Code for ESP8266 relay 1ch
by axiomnote on Tue Jan 14, 2020 3:19 pm
Hello there,
i am fresh new and have no experience but have good will :)
i have esp8266 relay 1ch and want to use it on io.adafruit to turn it on/off.... i have only esp8266 relay, CH 340 USB programmer for transferring code to esp-01 and nothing else
i have this code, but this code is not working..when i start this code when i press turn off/on it only affects led on esp-01 and relay is always on and cannot be switched off...
please for you professional help and where to find code
  This is the code for the project DIY Sonoff using ESP8266
  Original code is from
  Adafruit MQTT Library ESP8266 Example
  Code edited by
  Sachin Soni
  http://www.techiesms.com
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#define relay 2
/************************* WiFi Access Point *********************************/
#define WLAN_SSID       "...your SSID..."
#define WLAN_PASS       "...your password..."
/************************* Adafruit.io Setup *********************************/
#define AIO_SERVER      "io.adafruit.com"
#define AIO_SERVERPORT  1883                   // use 8883 for SSL
#define AIO_USERNAME    "...your AIO username (see https://accounts.adafruit.com)..."
#define AIO_KEY         "...your AIO key..."
/************ Global State (you don't need to change this!) ******************/
// Create an ESP8266 WiFiClient class to connect to the MQTT server.
WiFiClient client;
// or... use WiFiFlientSecure for SSL
//WiFiClientSecure client;
// Setup the MQTT client class by passing in the WiFi client and MQTT server and login details.
Adafruit_MQTT_Client mqtt(&client, AIO_SERVER, AIO_SERVERPORT, AIO_USERNAME, AIO_KEY);
/****************************** Feeds ***************************************/
// Setup a feed called 'photocell' for publishing.
// Notice MQTT paths for AIO follow the form: <username>/feeds/<feedname>
//Adafruit_MQTT_Publish photocell = Adafruit_MQTT_Publish(&mqtt, AIO_USERNAME "/feeds/photocell");
// Setup a feed called 'onoff' for subscribing to changes.
Adafruit_MQTT_Subscribe onoffbutton = Adafruit_MQTT_Subscribe(&mqtt, AIO_USERNAME "/feeds/Sonoff_1");
/*************************** Sketch Code ************************************/
// Bug workaround for Arduino 1.6.6, it seems to need a function declaration
// for some reason (only affects ESP8266, likely an arduino-builder bug).
void MQTT_connect();
  Serial.begin(115200);
  delay(10);
  Serial.println(F("Adafruit MQTT demo"));
  // Connect to WiFi access point.
  Serial.println(); Serial.println();
  Serial.print("Connecting to ");
  Serial.println(WLAN_SSID);
  WiFi.begin(WLAN_SSID, WLAN_PASS);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");
  Serial.println();
  Serial.println("WiFi connected");
  Serial.println("IP address: "); Serial.println(WiFi.localIP());
  pinMode(relay,OUTPUT);
  // Setup MQTT subscription for onoff feed.
  mqtt.subscribe(&onoffbutton);
uint32_t x=0;
  // Ensure the connection to the MQTT server is alive (this will make the first
  // connection and automatically reconnect when disconnected).  See the MQTT_connect
  // function definition further below.
  MQTT_connect();
  // this is our 'wait for incoming subscription packets' busy subloop
  // try to spend your time here
  Adafruit_MQTT_Subscribe *subscription;
  while ((subscription = mqtt.readSubscription(1))) {
    if (subscription == &onoffbutton) {
      Serial.print(F("Got: "));
      Serial.println((char *)onoffbutton.lastread);
      uint16_t state = atoi((char *)onoffbutton.lastread);
      digitalWrite(relay,state);
  // ping the server to keep the mqtt connection alive
  // NOT required if you are publishing once every KEEPALIVE seconds
  if(! mqtt.ping()) {
    mqtt.disconnect();
// Function to connect and reconnect as necessary to the MQTT server.
// Should be called in the loop function and it will take care if connecting.
void MQTT_connect() {
  int8_t ret;
  // Stop if already connected.
  if (mqtt.connected()) {
    return;
  Serial.print("Connecting to MQTT... ");
  uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0) { // connect will return 0 for connected
       Serial.println(mqtt.connectErrorString(ret));
       Serial.println("Retrying MQTT connection in 5 seconds...");
       mqtt.disconnect();
       delay(5000);  // wait 5 seconds
       retries--;
       if (retries == 0) {
         // basically die and wait for WDT to reset me
         while (1);
  Serial.println("MQTT Connected!");
Last edited by adafruit_support_mike on Wed Jan 15, 2020 5:40 am, edited 1 time in total.
Reason: added CODE tags
axiomnote
Re: Code for ESP8266 relay 1ch
by adafruit_support_mike on Wed Jan 15, 2020 5:43 am
Add a Serial.print() statement in this part of the code to see what values your code gets from the MQTT broker:
by axiomnote on Thu Jan 16, 2020 10:11 am
hi mike
as i see in code that i sent there is also this serial.print
but if you thought something else to be done from my side in programming i must tell you that
i have no knowledge in programming
thats why i asked for help
axiomnote
by axiomnote on Thu Jan 16, 2020 10:26 am
and also i found this code which is working and turning relay on/off on webserver
but i dont know how to add this code to be used with adafruit
what i need to add to this code so i can use relay from adafruit
const char* ssid = "YOUR SSID"; // fill in here your router or wifi SSID
const char* password = "YOUR PASSWORD"; // fill in here your router or wifi password
 #define RELAY 0 // relay connected to  GPIO0
WiFiServer server(80);
void setup()
  Serial.begin(115200); // must be same baudrate with the Serial Monitor
  pinMode(RELAY,OUTPUT);
  digitalWrite(RELAY, LOW);
  // Connect to WiFi network
  Serial.println();
  Serial.println();
  Serial.println(ssid);
  WiFi.begin(ssid, password);
    delay(500);
    Serial.print(".");
  Serial.println("");
  // Start the server
  server.begin();
  Serial.println("Server started");
  // Print the IP address
  Serial.print("Use this URL to connect: ");
  Serial.print("https://192.168.0.178/");
  Serial.print(WiFi.localIP());
  Serial.println("/");
void loop()
  // Check if a client has connected
  WiFiClient client = server.available();
  if (!client)
    return;
  // Wait until the client sends some data
  Serial.println("new client");
  while(!client.available())
    delay(1);
  // Read the first line of the request
  String request = client.readStringUntil('\r');
  Serial.println(request);
  client.flush();
  // Match the request
  int value = LOW;
  if (request.indexOf("/RELAY=ON") != -1)
    Serial.println("RELAY=ON");
    digitalWrite(RELAY,LOW);
    value = LOW;
  if (request.indexOf("/RELAY=OFF") != -1)
    Serial.println("RELAY=OFF");
    digitalWrite(RELAY,HIGH);
    value = HIGH;
  // Return the response
  client.println("HTTP/1.1 200 OK");
  client.println("Content-Type: text/html");
  client.println(""); //  this is a must
  client.println("<!DOCTYPE HTML>");
  client.println("<html>");
  client.println("<head><title>ESP8266 RELAY Control</title></head>");
  client.print("Relay is now: ");
  if(value == HIGH)
    client.print("OFF");
  else
    client.print("ON");
  client.println("<br><br>");
  client.println("Turn <a href=\"/RELAY=OFF\">OFF</a> RELAY<br>");
  client.println("Turn <a href=\"/RELAY=ON\">ON</a> RELAY<br>");
    client.println("</html>");
  delay(1);
  Serial.println("Client disonnected");
  Serial.println("");
axiomnote
by brubell on Wed Jan 22, 2020 12:02 pm
I can't do much to debug without the output from your serial monitor. Could you copy and paste the output into this thread?
For reference regarding using the Arduino Serial Monitor, please check this page: https://learn.adafruit.com/adafruit-ard ... al-monitor
brubell
