adafruit IO feed problem
by secretalpaca on Wed Jan 22, 2020 6:33 am
I am using NodeMCU and I am doing this project following this link: https://learn.adafruit.com/adafruit-io- ... overview-2
The serial monitor only outputs "LOW" when toggle feed is turned ON and OFF. I checked the feed history and there are crosses at the right side of the chart for all the times I have pressed ON and OFF. The feed graph is also empty.
The light does not switch on at all.
secretalpaca
Re: adafruit IO feed problem
by brubell on Wed Jan 22, 2020 11:15 am
Make sure the Toggle Block on your dashboard is set up like the following screenshot:
The red X's are buttons for deleting feed data
brubell
by secretalpaca on Wed Jan 29, 2020 5:31 am
brubell wrote:Make sure the Toggle Block on your dashboard is set up like the following screenshot:
It works now. Thanks so much!
secretalpaca
