IO not reading windseppd
by Sparky56 on Wed Jan 22, 2020 7:28 pm
I have a problem with the IO not picking up my windspeed from the pyportal weather station.
I get a reading in the serial monitor.
Have tried wind speed, wind_speed in IO, it didn't work
can someone point me in the right direction?
Sparky56
Re: IO not reading windseppd
by adafruit_support_carter on Wed Jan 22, 2020 7:59 pm
Did you setup the feed in your Adafruit IO account?
https://learn.adafruit.com/pyportal-iot ... -feeds-2-6
It should show up as shown on the screen capture there.
by Sparky56 on Wed Jan 22, 2020 8:12 pm
this is a cut n paste of my IO page
Group / Feed Key Last value Recorded
Default default
Weatherstation weatherstation
altitude weatherstation.altitude 380.561 1 minute ago
eco2 weatherstation.eco2 400 1 minute ago
humidity weatherstation.humidity 47.7775 1 minute ago
pressure weatherstation.pressure 968.36 1 minute ago
temperature weatherstation.temperature 21.3623 1 minute ago
tvoc weatherstation.tvoc 0 1 minute ago
uvindex weatherstation.uvindex 0.0 1 minute ago
uvlevel weatherstation.uvlevel 2.24367 1 minute ago
windspeed weatherstation.windspeed about 1 hour ago
this in indoors for setup and I have a fan for wind. My PyPortal is showing 2.31m/s
Sparky56
by adafruit_support_carter on Wed Jan 22, 2020 8:23 pm
I wonder if this related to subscription level. The guide mentions needing a IO+ account:
https://learn.adafruit.com/pyportal-iot ... t-io-setup
Do you have that or are you using the free level?
by Sparky56 on Wed Jan 22, 2020 8:26 pm
I have the IO+
Sparky56
by adafruit_support_carter on Wed Jan 22, 2020 8:46 pm
OK, should be fine then.
I think I see it. You've set up one too many feeds. You have 9. There should only be 8.
Compare to list in guide:
The feed names are queried from the feed list and setup for you. Windspeed is expected to be the 8th entry:
https://github.com/adafruit/Adafruit_Le ... ode.py#L89
With your current setup, the windspeed is probably showing up in your uvlevel feed. Remove the uvlevel feed. That's the one that appears to be extra.
by Sparky56 on Wed Jan 22, 2020 9:00 pm
Your the Man of the hour.
that did it. Thanks
I have another post about wind speed m/s and temperature in fahrenheit,
can you help?
Sparky56
by adafruit_support_carter on Wed Jan 22, 2020 9:12 pm
Responded with some unit conversion formulas.
