Custom IFTTT triggers
by johnlavik on Fri Jan 24, 2020 11:28 am
Greetings, I've created a temperature alarm for my refrigerator using the Feather Huzzah and a TMP36. I'm sending data to AdafruitIO and have set up IFTTT to alert me when the temperature rises above a threshold. I would prefer to have IFTTT wait for several temps over threshold before notifying me, but it seems like the only trigger available is a single comparison of value against threshold.
I saw in another post (I forget where) that someone seemed to have accomplished this. Does anyone know if it is possible (I assume it is) and how to do create a trigger like "if 3 consecutive readings > 50 then ...?
johnlavik
Re: Custom IFTTT triggers
by brubell on Tue Jan 28, 2020 11:31 am
Adafruit IO Triggers can currently only execute based on one conditional statement.
To accomplish what you stated- your code would perform the if 3 consecutive readings > 50 then .. conditional statement. If it's true, it'd send a specific "trigger" value to the Adafruit IO feed. The trigger you set up would check this feed for the specific trigger value.
brubell
by johnlavik on Tue Jan 28, 2020 1:38 pm
Thanks Brubell. That seems like a reasonable workaround (though it wouldn't allow me to monitor temps at the same time.) I suppose I could set up two feeds... one to monitor and one for the trigger. Thanks!
johnlavik
