Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more.
Arduino with ESP8266 connecting to Adafruit IO
by Lucifer22334 on Tue Jan 28, 2020 1:46 am
I was searching for a way to connect my Arduino Uno to Adafruit IO but couldn't find a thing. I am connecting Arduino Uno with the ESP8266 Module. My Arduino is connected with 3 Analog and 1 Digital sensor so using the ESP8266 I will give Arduino Wifi connectivity to connect with the Internet and communicate with Adafruit IO.
I was searching on the Adafruit page for above but got scammed. on this page: https://learn.adafruit.com/series/adafruit-io-basics
there is a tutorial "Adafruit IO Basics: Digital Input" which has Arduino in its Image and when I opened it, on left-hand side was written Arduino Wiring, code, etc. so I thought this whole tutorial is for showing how can we connect Arduino to Adafruit cloud using ESP8266 but on wiring part I got to know that they were using there own Adafruit module and library is specific to their own boards. Please change that. We, beginners, get lost due to this.
And also if anyone knows how to communicate Arduino with Adafruit IO using ESP8266 Please do tell.
Lucifer22334
Re: Arduino with ESP8266 connecting to Adafruit IO
by TI545 on Wed Jan 29, 2020 12:41 am
Interesting comment. I have my esp8266 connected directly to IO.adafruit.com, but not with an arduino uno. Just the 8266 on its own. That method works great, adafruit provided the 'example' sketch in the arduino IDE as part of the adding esp8266 to the IDE boards manager. I don't see the scam photo with the arduino from your link.
The esp8266 has enough memory and flash to be used without the arduino. But of course, it only has one ADC and you want 3 ADC. How do you have the Uno and the esp8266 communicating? I haven't done it but I assume you could send your 3 ADC values to the esp8266 via UART/SPI and then use the 8266 io.adafruit sketch to upload it to io.adafruit.
TI545
by Lucifer22334 on Wed Jan 29, 2020 1:29 am
TI545 wrote:Interesting comment. I have my esp8266 connected directly to IO.adafruit.com, but not with an Arduino UNO. Just the 8266 on its own. That method works great, adafruit provided the 'example' sketch in the Arduino IDE as part of the adding esp8266 to the IDE boards manager. I don't see the scam photo with the Arduino from your link.
The esp8266 has enough memory and flash to be used without the Arduino. But of course, it only has one ADC and you want 3 ADC. How do you have the Uno and the esp8266 communicating? I haven't done it but I assume you could send your 3 ADC values to the esp8266 via UART/SPI and then use the 8266 io.adafruit sketch to upload it to io.adafruit.
What do you see in the below image An Arduino with wifi ethernet shield or something else:
And What do you expect on reading the Arduino Wiring on the left panel and from the above Image? Then they simply write Hardware Adafruit's one:
Rest on every tutorial they had their own board Image. That's why I said I got scammed. Every newbie and person with Arduino experience will expect this only.
And also like your idea of how to send the data to Adafruit IO and it can be an option but I was thinking maybe there would a library for Arduino Uno to connect with the Adafruit cloud using the ESP8266 module not just only ESP8266.
Lucifer22334
by adafruit_support_mike on Wed Jan 29, 2020 5:23 am
[moved to the Adafruit.IO forum]
by brubell on Wed Jan 29, 2020 11:47 am
The Arduino Uno (unless you're using the Arduino Uno V2 with WiFi) does not have a WiFi module built-in. You will need a WiFi module to connect it to the internet. We recommend picking up the AirLift shield (https://www.adafruit.com/product/4285) as it's pin-compatible with the Arduino Uno's shield headers.
This guide and the Adafruit IO Arduino library used by the guide (https://github.com/adafruit/Adafruit_IO_Arduino) are compatible with Arduino-compatible boards including the ESP8266 and an Arduino Uno with a WiFi module.
The wiring will need to be modified if you're using a board other than the Feather Huzzah.
- brent r.
brubell
by Lucifer22334 on Thu Jan 30, 2020 1:52 am
brubell wrote:Hi,
- brent r.
So If I am using an Arduino UNO with a WiFi module ESP8266 and I just want to program Arduino, not ESP8266 (Just a medium to connect to Internet through WiFi) and connect to Adafruit is it possible using your library "https://github.com/adafruit/Adafruit_IO_Arduino". If it is then how?
Lucifer22334
by Lucifer22334 on Fri Jan 31, 2020 6:10 am
brubell wrote:Hi,
- brent r.
Please answer or anyone answers my above question asked.
Lucifer22334
by brubell on Fri Jan 31, 2020 12:09 pm
Please do not bump posts.
Could you link to the wifi module you're using?
brubell
by Lucifer22334 on Mon Feb 03, 2020 1:58 am
Sorry, I will not do it again. I am using ESP8266 with Arduino UNO and I could link to it via AT command or UART.
Lucifer22334
by goveil1 on Thu Mar 12, 2020 11:59 am
You have probably figured this out already, but I used I2C on several projects to have the UNO, or Mega talk to the 8266. Because the 8266 has to be a master and not a slave, I used a wired interrupt to trigger the 8266 to do a wire request and then the appropriate Wire library calls back and forth for communication. If you are interested and still having trouble, I can send you code, etc....
goveil1
by brubell on Thu Mar 12, 2020 12:03 pm
goveil1 wrote:You have probably figured this out already, but I used I2C on several projects to have the UNO, or Mega talk to the 8266. Because the 8266 has to be a master and not a slave, I used a wired interrupt to trigger the 8266 to do a wire request and then the appropriate Wire library calls back and forth for communication. If you are interested and still having trouble, I can send you code, etc....
Hi Goveil1, please do not bump old posts. Please create a new post so we can check it out, you may link to this post.
brubell
