AIO With FONA A push model?
by treyco on Thu Jan 30, 2020 10:24 pm
I’m just trying to understand using Arduino with FONA as a AIO client. My understanding of MQTT is that it pushes published data to subscribers through a persistent TCP pipe. I’m using the MQTT FONA example project. Everything hooks up and works. However, I’m noticing that this line in code takes approximately 500 milliseconds to execute even if there is no new data.
 while ((subscription = mqtt.readSubscription(10)))
I’m using a millis timer in the loop to make sure I don’t violate the rate, but I don’t understand why checking for new data would count against my rate and why it takes so long to execute if it’s push technology.
treyco
Re: AIO With FONA A push model?
by brubell on Fri Jan 31, 2020 12:12 pm
the readSubscription function performs an Adafruit IO MQTT API (https://io.adafruit.com/api/docs/mqtt.h ... o-mqtt-api) action which counts against your data rate.
It's usually quicker with WiFi, there could be a delay to reach the Adafruit IO MQTT broker over cellular depending on your proximity to cell towers.
brubell
by treyco on Fri Jan 31, 2020 12:29 pm
So back to my original question. Does this mean that the adafruit implementation of MQTT is a polling model? I was under the impression that it was a push model.
treyco
