Arduino Mega and NodeMCU
by secretalpaca on Mon Feb 03, 2020 11:39 pm
Hi!
I want to use Arduino Mega to control 4 lamps using Adafruit IO toggle feeds. Instead of adding esp8266 wifi module, I would like to connect NodeMCU to Arduino Mega through using SDA and SCL. I will be also using the code from https://learn.adafruit.com/adafruit-io- ... overview-2 for nodeMCU, that has been already tested and works. Is there any sample code for Arduino Mega?
secretalpaca
Re: Arduino Mega and NodeMCU
by adafruit_support_mike on Tue Feb 04, 2020 5:34 am
NodeMCU isn't a device. It's software that runs on ESP8266 and ESP32 boards.
Which board do you want to use?
