Arduino Uno Ethernet Shield connect to AIO
by Weather411 on Thu Feb 06, 2020 5:23 pm
Hello all,
Been working this problem for several days and after many 'Google' searches, I'm still stumped.
As subject heading suggests, I'm trying to get my Arduino Uno w/ Ethernet Shield (W5500) connected with my Adafruit IO+ account. I have lots of feeds that update with a combination of ESP32 and ESP8266 boards with no problems using the Adafruit IO library.
Note: I built a simple local web server with a DHT22 using the Ethernet shield and it works perfectly.
Adafruit IO v3.4.0
Arduino AVR Boards v1.8.2
Ethernet v2.0.0 (I'm aware that Ethernet2 is now obsolete)
Sketch: example "adafruitio_00_publish"
Within the config.h tab, after I include my IO_USERNAME and IO_KEY, comment out the WIFI and FONA sections but include the Ethernet section (#include "AdafruitIO_Ethernet.h", AdafruitIO_Ethernet io(IO_USERNAME, IO_KEY);) I keep getting the same compile error:
virtual void _disconnect() = 0;
exit status 1
cannot declare variable 'io' to be of abstract type 'AdafruitIO_Ethernet'
Is this a known bug? Can somebody test and confirm this result (possible fix?)...thank you in advance!
Mike
Weather411
Re: Arduino Uno Ethernet Shield connect to AIO
by brubell on Fri Feb 07, 2020 10:31 am
Could you try it with the Arduino Ethernet library (not adafruit ethernet2)
brubell
by Weather411 on Fri Feb 07, 2020 5:46 pm
Hello brubell
The example sketch from Adafruit IO does not include the Ethernet library, only "AdafruitIO_Ethernet.h" .... this is where the problem lies (look at the error code again)
I only mentioned the Ethernet library since I have other projects with my Uno ethernet shield (using the Ethernet library, not Ethernet2) and it works fine. Hardware is good.
I can attempt to re-write the code without using the Adafruit library (to post to AIO) using just the Ethernet library but that will take a lot of time (learning curve).
Weather411
by brubell on Tue Feb 11, 2020 11:48 am
Weather411 wrote:Hello brubell
I'm able to replicate this issue. I added a bug/issue for it on the library and will get to it in the next two weeks: https://github.com/adafruit/Adafruit_IO ... issues/110
brubell
by Weather411 on Wed Feb 12, 2020 11:46 am
Great thank you!
Weather411
