Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more.
Arduino Uno Ethernet Shield connect to AIO
by Weather411 on Thu Feb 06, 2020 5:23 pm
Hello all,
Been working this problem for several days and after many 'Google' searches, I'm still stumped.
As subject heading suggests, I'm trying to get my Arduino Uno w/ Ethernet Shield (W5500) connected with my Adafruit IO+ account. I have lots of feeds that update with a combination of ESP32 and ESP8266 boards with no problems using the Adafruit IO library.
Note: I built a simple local web server with a DHT22 using the Ethernet shield and it works perfectly.
Adafruit IO v3.4.0
Arduino AVR Boards v1.8.2
Ethernet v2.0.0 (I'm aware that Ethernet2 is now obsolete)
Sketch: example "adafruitio_00_publish"
Within the config.h tab, after I include my IO_USERNAME and IO_KEY, comment out the WIFI and FONA sections but include the Ethernet section (#include "AdafruitIO_Ethernet.h", AdafruitIO_Ethernet io(IO_USERNAME, IO_KEY);) I keep getting the same compile error:
virtual void _disconnect() = 0;
exit status 1
cannot declare variable 'io' to be of abstract type 'AdafruitIO_Ethernet'
Is this a known bug? Can somebody test and confirm this result (possible fix?)...thank you in advance!
Mike
Weather411
Re: Arduino Uno Ethernet Shield connect to AIO
by brubell on Fri Feb 07, 2020 10:31 am
Could you try it with the Arduino Ethernet library (not adafruit ethernet2)
brubell
by Weather411 on Fri Feb 07, 2020 5:46 pm
Hello brubell
The example sketch from Adafruit IO does not include the Ethernet library, only "AdafruitIO_Ethernet.h" .... this is where the problem lies (look at the error code again)
I only mentioned the Ethernet library since I have other projects with my Uno ethernet shield (using the Ethernet library, not Ethernet2) and it works fine. Hardware is good.
I can attempt to re-write the code without using the Adafruit library (to post to AIO) using just the Ethernet library but that will take a lot of time (learning curve).
Weather411
by brubell on Tue Feb 11, 2020 11:48 am
Weather411 wrote:Hello brubell
I'm able to replicate this issue. I added a bug/issue for it on the library and will get to it in the next two weeks: https://github.com/adafruit/Adafruit_IO ... issues/110
brubell
by Weather411 on Wed Feb 12, 2020 11:46 am
Great thank you!
Weather411
by WiddeA on Sun Mar 15, 2020 5:10 am
Hi, I ran into this problem last night, is there any update?
Greetings from Stockholm
WiddeA
by The_Bucho on Thu Mar 19, 2020 4:51 pm
Same here. Here's my Config.h
Though there are more lines that I feel should be commented out, I followed exactly the instructions at https://learn.adafruit.com/adafruit-io-basics-digital-input/arduino-network-config first. Then I experimented with commenting out everything else, too. No luck.
/************************ Adafruit IO Config *******************************/
// visit io.adafruit.com if you need to create an account,
// or if you need your Adafruit IO key.
#define IO_USERNAME "☐"
#define IO_KEY "☐"
/******************************* WIFI **************************************/
// the AdafruitIO_WiFi client will work with the following boards:
//   - HUZZAH ESP8266 Breakout -> https://www.adafruit.com/products/2471
//   - Feather HUZZAH ESP8266 -> https://www.adafruit.com/products/2821
//   - Feather HUZZAH ESP32 -> https://www.adafruit.com/product/3405
//   - Feather M0 WiFi -> https://www.adafruit.com/products/3010
//   - Feather WICED -> https://www.adafruit.com/products/3056
//   - Adafruit PyPortal -> https://www.adafruit.com/product/4116
//   - Adafruit Metro M4 Express AirLift Lite ->
//   https://www.adafruit.com/product/4000
//   - Adafruit AirLift Breakout -> https://www.adafruit.com/product/4201
//   - Adafruit AirLift Shield -> https://www.adafruit.com/product/4285
//   - Adafruit AirLift FeatherWing -> https://www.adafruit.com/product/4264
// #define WIFI_SSID "your_ssid"
// #define WIFI_PASS "your_pass"
// uncomment the following line if you are using airlift
// #define USE_AIRLIFT
// uncomment the following line if you are using winc1500
// #define USE_WINC1500
// comment out the following lines if you are using fona or ethernet
//#include "AdafruitIO_WiFi.h"
#if defined(USE_AIRLIFT) || defined(ADAFRUIT_METRO_M4_AIRLIFT_LITE) ||         \
    defined(ADAFRUIT_PYPORTAL)
// Configure the pins used for the ESP32 connection
#if !defined(SPIWIFI_SS) // if the wifi definition isnt in the board variant
// Don't change the names of these #define's! they match the variant ones
#define SPIWIFI SPI
#define SPIWIFI_SS 10 // Chip select pin
#define NINA_ACK 9    // a.k.a BUSY or READY pin
#define NINA_RESETN 6 // Reset pin
#define NINA_GPIO0 -1 // Not connected
#endif
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS, SPIWIFI_SS,
                   NINA_ACK, NINA_RESETN, NINA_GPIO0, &SPIWIFI);
#else
//AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
#endif
/******************************* FONA **************************************/
// the AdafruitIO_FONA client will work with the following boards:
//   - Feather 32u4 FONA -> https://www.adafruit.com/product/3027
// uncomment the following two lines for 32u4 FONA,
// and comment out the AdafruitIO_WiFi client in the WIFI section
// #include "AdafruitIO_FONA.h"
// AdafruitIO_FONA io(IO_USERNAME, IO_KEY);
/**************************** ETHERNET ************************************/
// the AdafruitIO_Ethernet client will work with the following boards:
//   - Ethernet FeatherWing -> https://www.adafruit.com/products/3201
// uncomment the following two lines for ethernet,
And here's the error I get on compile:
In file included from /var/folders/w9/_tsz01hx45vft50xkn3mn6800000gn/T/arduino_modified_sketch_463362/adafruitio_06_digital_in.ino:19:0:
config.h:70:22: error: cannot declare variable 'io' to be of abstract type 'AdafruitIO_Ethernet'
In file included from sketch/config.h:69:0,
/Users/themaestro/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/AdafruitIO_Ethernet.h:35:7: note:   because the following virtual functions are pure within 'AdafruitIO_Ethernet':
 class AdafruitIO_Ethernet : public AdafruitIO {
In file included from /Users/themaestro/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/AdafruitIO_Ethernet.h:28:0,
                 from sketch/config.h:69,
/Users/themaestro/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/AdafruitIO.h:136:16: note:    virtual void AdafruitIO::_disconnect()
Multiple libraries were found for "WiFi.h"
 Used: /Users/themaestro/Library/Arduino15/packages/esp32/hardware/esp32/1.0.4/libraries/WiFi
 Not used: /Applications/Arduino.app/Contents/Java/libraries/WiFi
exit status 1
The_Bucho
by WiddeA on Fri Mar 20, 2020 2:47 am
I've now managed to make the code compile and function OK using the following library versions:
* ArduinoHttpClient 0.3.1
* Adafruit MQTT Library 1.01
* Adafruit IO Arduino 3.3.0
The final trick was to comment out this #ifdef in Adafruit_MQTT.cpp:
//#if defined(ARDUINO_SAMD_ZERO) || defined(ARDUINO_SAMD_MKR1000) || defined(ARDUINO_ARCH_SAMD)
static char *dtostrf (double val, signed char width, unsigned char prec, char *sout) {
 char fmt[20];
 sprintf(fmt, "%%%d.%df", width, prec);
 sprintf(sout, fmt, val);
 return sout;
//#endif
Take care,
WiddeA
WiddeA
by The_Bucho on Wed Mar 25, 2020 4:37 pm
@widdleA, can I get you to comment on this:
Am I correct in assuming that I need to download the .zip from GH of the MQTT library, edit it locally to comment out those lines in the .ccp, then upload the library as a .zip to my IDE with another name or version...then include that version? I just don't see how else you get access to the actual lines of the library.
Do I have this right?
The_Bucho
by WiddeA on Thu Mar 26, 2020 3:30 am
you could, but what I did was actually using the library manager of the Adafruit IDE to download the libraries of the versions I mentioned. The file you need to find and modify on your computer is "Adafruit_MQTT.cpp". On my PC I found it at the location "whatever_path\libraries\arduino_264042\Adafruit_MQTT.cpp". Pls let me know if you need a better step-by-step description of what to do. Though if you manage to make it compile and work you could maybe share how, I admit my description wan't the best :-)
WiddeA
