Dashboard Map
Dashboard Map
by mauiphill on Mon Feb 10, 2020 4:17 am
Is there any way to clear the location data on a map within the dashboard (gps location)
I do see the option “ Hours of History (0 for realtime)” but it doesn’t clear after the time I put into it.
mauiphill
Re: Dashboard Map
by brubell on Tue Feb 11, 2020 10:58 am
You could clear the dashboard block's location data by sending 0's in the latitude/longitude/altitude metadata associated with the feed linked to the dashboard block.
brubell
Re: Dashboard Map
by vamo on Fri Oct 16, 2020 4:36 am
Hi brubell,
I tried the method you suggested but it seems not to work.
I inserted some points, then one point with lat = lon = ele = 0, then some more points.
The dashboard keeps showing the old points before the all-zeroes point insertion, see figures...
old_data_still are_visible.png (17.94 KiB) Viewed 18 times
Am I doing wrong? Any suggestion...?
Many thanks,
Valerio
vamo
