🎁📬❄️📦 Holiday Shipping Deadlines are approaching! International customers and domestic ground - get your orders in 12/9/2020 📦❄️📬🎁
Dashboard Map
Dashboard Map
by mauiphill on Mon Feb 10, 2020 4:17 am
Is there any way to clear the location data on a map within the dashboard (gps location)
I do see the option “ Hours of History (0 for realtime)” but it doesn’t clear after the time I put into it.
mauiphill
Re: Dashboard Map
by brubell on Tue Feb 11, 2020 10:58 am
You could clear the dashboard block's location data by sending 0's in the latitude/longitude/altitude metadata associated with the feed linked to the dashboard block.
brubell
Re: Dashboard Map
by vamo on Fri Oct 16, 2020 4:36 am
Hi brubell,
I tried the method you suggested but it seems not to work.
I inserted some points, then one point with lat = lon = ele = 0, then some more points.
The dashboard keeps showing the old points before the all-zeroes point insertion, see figures...
old_data_still are_visible.png (17.94 KiB) Viewed 12801 times
Am I doing wrong? Any suggestion...?
Many thanks,
Valerio
vamo
Re: Dashboard Map
by brubell on Fri Oct 23, 2020 9:54 am
I was incorrect. Each location will update a "pin" on the map block. You might want to delete the feed and start over.
brubell
Re: Dashboard Map
by vamo on Thu Dec 03, 2020 1:31 pm
The map still shows old data even if the "Hours of History" display interval is set to a short time, for istance 24 hours...
The problem has been reported several times, in this topic but also here:
viewtopic.php?f=56&p=836266#p836266
Is it possible that the problem is so complex to correct ?
It just seems a matter of inserting an if in the plotting of the points on the graph...
Can we hope to find a gift under the tree for Christmas...?
Kind regards to you all, and many thanks for all your work...
VALERIO
vamo
