Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more.
Set a slider block to initial value from sketch
by JackTheSE on Wed Feb 19, 2020 7:31 am
EDIT: Never mind. I needed to add myio.run(); after the save command. Now it works...
I have a feed set up in a group and reference it from my sketch using
AdafruitIO_Feed *SliderFrzrPtr = myio.feed("todd-fridge.freezer-cal");
I use that feed and a slider block to set a calibration value for a temp sensor. In the call back routine for the feed I have the line
CalValue = data->value();
where CalValue is a global String variable. I save CalValue to SPIFFS. Upon a restart of the ESP32 I'm using, I read in the saved value from SPIFFS into CalValue, and I would like to make sure the slider is set to that initial value on the dashboard. I've tried the command SliderFrzrPtr->save(CalValue); but it doesn't change the slider position at all. Is it possible to do this? What am I doing wrong?
JackTheSE
