MQTT JSON + Adafruit IO
by Copy on Sat Feb 22, 2020 10:47 am
I found this app that can control MQTT-enabled lights, but it sends the brightness values is in a JSON format. Here is an example
 "mqqt_dashboard":{
  "color":"#FFFFFF",
  "brightness": 100
Can I make that work with Adafruit IO?
The app : https://play.google.com/store/apps/deta ... tdashboard
Copy
Re: MQTT JSON + Adafruit IO
by Copy on Sun Feb 23, 2020 6:06 am
UPDATE:
I found out that I need to send "value" not "brightness"
Is there any way to change that
Copy
by brubell on Tue Feb 25, 2020 9:50 am
Copy wrote:UPDATE:
Adafruit IO Feeds use the following JSON format:
  "id": "string",
  "value": "string",
  "feed_id": 0,
  "feed_key": "string",
  "created_at": "datetime",
  "location": {},
  "lat": 0.0,
  "lon": 0.0,
  "ele": 0.0,
  "created_epoch": 0,
  "expiration": "datetime"
You may want to contact the application developer to see if it's possible to edit the JSON from the application, before it's sent to Adafruit IO.
brubell
