Unable to connect to adafruit io
by johnkenas on Tue Feb 25, 2020 6:01 am
im currently working on my IoT project which requires some remote control which i found it possible using adafruit io. But i'm not very sure with whether it will be useful to me not as my existing hardware does not use adafruit hardware but it is some thing similar to FONA808 it is a local board wit SIM808. So,my question is whether I will be able to use adafruit IO or not?.
johnkenas
Re: Unable to connect to adafruit io
by brubell on Tue Feb 25, 2020 9:48 am
You may attempt to follow the instructions on https://learn.adafruit.com/geofencing-w ... dafruit-io. If you can't get that going - contact the hardware vendor for information about sending HTTP requests with your board so you can interface with the Adafruit IO HTTP API (https://io.adafruit.com/api/docs/#adafruit-io-http-api).
brubell
