Unable to configure Telegraf MQTT Output
by MinusMyX on Tue Mar 03, 2020 5:38 am
Hi, im new in Adafruit , made some python Projects and working perfectly. But when i move some other sensor information througt Telegraf-SNMP-MQTT , im unable to publish .
I've tried some options to fit Adafruit IO naming conventions, but when i think it's configured none of the debug tells me nothing even in Monitor Section.
Sometimes i say that Telegraf Adds my hostname in my feed name, so instead MYUSERNAME/feeds/FeedName i have seen MYUSERNAME/feeds/HOSTNAME/FeedName when firstly configuring, but even using a group named like the hostname that telegraf adds. But that does not match correctly to the feed name, because it would be MYUSERNAME/feeds/HOSTNAME.FeedName
¿Any idea how to renaming topics with Telegraf?
[[inputs.snmp]]
agents = [ "192.168.1.99:161" ]
version = 2
community = "$MYSNMPCOMMUNITY"
[[outputs.mqtt]]
## URLs of mqtt brokers
servers = ["io.adafruit.com:1883"]
## topic for producer messages
topic_prefix = "$MYADAFRUITUSERNAME/feeds/"
## QoS policy for messages
## 0 = at most once
## 1 = at least once
## 2 = exactly once
qos = 1
MinusMyX
Re: Unable to configure Telegraf MQTT Output
by brubell on Tue Mar 03, 2020 10:31 am
It should be:
If you're publishing to an invalid feed with an error, the io monitor page (http://io.adafruit.com/monitor) should display a live-feed of errors.
Does Telegraf-SNMP-MQTT have any type of debugging output where you can view what the topic string looks like when it publishes? Does it return an authorization error?
brubell
