Validation failed:Name has already been taken...
by RDMartin on Fri Mar 06, 2020 4:21 pm
I teach a course where the students design and build an Arduino UNO shield that sends sensor data to Adafruit IO using an ESP8266. This year when I try to send a feed to Adafruit IO I get the following error "unexpected error saving data on xxxxxxx/feeds/counter, Validation failed: Name has already been taken, Key has already been taken"
I started over with a Huzzah8266 feather and went thru the Adafruit IO Basics:ESP8266, Arduino, & Adafruit IO! tutorial.
I can connect to the "wifitest.adafruit.com" host but when I run adafruitio_00_publish it connects and sends the counter but I get the same error in Adafruit IO.
Has something changed in the libraries in the last year that I need to account for to get my feeds to show up?!
RDMartin
Re: Validation failed:Name has already been taken...
by brubell on Fri Mar 06, 2020 5:20 pm
It's likely trying to create another feed named counter, you may have a feed with the key set to counter.
Navigate to your feeds page and check for a key called counter and remove it.
Then, try running the sketch again.
If you're still having this issue, please respond and I'll take a look into it. The functionality of the core feed methods of this library hasn't changed.
brubell
by RDMartin on Fri Mar 06, 2020 5:59 pm
Thanks for the quick response. The funny thing is I have no feeds or even if I delete the all of the feeds I still get this error. I even tried generating a new AIO Key and I still get this error! I get a new error every time I sent data from the 8266. When I try to add a block to the dashboards no feeds are listed either.
adafruit IO feeds.jpg (148.61 KiB) Viewed 39 times
RDMartin
by brubell on Tue Mar 10, 2020 12:06 pm
This may be an account-related problem.
Could you please navigate to https://io.adafruit.com/feedback and click the Contact Adafruit IO Support button. Click "
There is an issue with Adafruit IO. Something is broken!" and include a link to this thread. Your request will be submitted along with Account details so we can assist you from there.
brubell
by RDMartin on Tue Mar 10, 2020 2:22 pm
Thanks. I completely deleted my IO account and started a new one and everything is working now!
RDMartin
