Grand Central M4 fails to connect using "AdafruitIO_WiFi.h"
by ahoadley on Mon Mar 09, 2020 7:47 pm
I am converting several Arduino projects over to use Adafruit IO, using Arduino IDE 1.8.12 and upgraded boards. I have my Metro M4 Airlift Lite boards up and running. My problem is with updating an Arduino Mega to a Metro M4 Grand Central connected to a Airlift ESP32 WiFi Co-Processor SPI Interface. I can run the connection test in the WiFiNINA library, including the WiFiSSLClient on the Metro M4 Grand Central. I figure this indicates the hardware is at least wired correctly. I wrote a test sketch to try to narrow down my issue, which I will include below. This sketch works on my Metro M4 Airlift Lite board and will compile OK on my Metro M4 Grand Central, but the sketch gets stuck in the "while (io.status() < AIO_CONNECTED) {" loop, generating a stream of:
18:41:58.972 -> *!1
18:41:59.491 -> *!1
I also found that upgrading the WiFiNINA library to 1.5 from 1.4 caused compiling error for both boards.
Any help on this will be appreciated.
Art
#define IO_USERNAME   "##############"
#define IO_KEY        "####################"
#define WIFI_SSID "###############"
#define WIFI_PASS "##################"
#define USE_AIRLIFT
#include "AdafruitIO_WiFi.h"
//#if defined(USE_AIRLIFT) || defined(ADAFRUIT_METRO_M4_AIRLIFT_LITE) ||         \
    defined(ADAFRUIT_PYPORTAL)
// Configure the pins used for the ESP32 connection
#if !defined(SPIWIFI_SS) // if the wifi definition isnt in the board variant
// Don't change the names of these #define's! they match the variant ones
  //AirLift Setup for the Adafruit Metro M4 Airlift Lite
    #define SPIWIFI SPI
    #define SPIWIFI_SS 10 // Chip select pin
    #define NINA_ACK 9    // a.k.a BUSY or READY pin
    #define NINA_RESETN 6 // Reset pin
    #define NINA_GPIO0 -1 // Not connected
  //AirLift Setup for the Adafruit Metro M4 Grand Central using Airlift ESP32 WiFi SPI Interface
    #define SPIWIFI SPI
    #define SPIWIFI_SS 27 // Chip select pin
    #define NINA_ACK 25    // a.k.a BUSY or READY pin
    #define NINA_RESETN 23 // Reset pin
#endif
AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS, SPIWIFI_SS,
                   NINA_ACK, NINA_RESETN, NINA_GPIO0, &SPIWIFI);
//#else
//AdafruitIO_WiFi io(IO_USERNAME, IO_KEY, WIFI_SSID, WIFI_PASS);
//#endif
#define SPIWIFI SPI
const long CycleTime = 1000;      // Time in ms between each program loop
long int counter = 0;
int CycleIndicatorPin = 13;
int NotificationControl = 0;
String ReturnStr = " ";
AdafruitIO_Time *iso = io.time(AIO_TIME_ISO);
String AdafruitTime;
String AdafruitHour;
String AdafruitMin;
AdafruitIO_Feed *output = io.feed("analog-test");
AdafruitIO_Feed *control = io.feed("test-on-off");
void setup()
  control->onMessage(handleMessage);
  // initialize the Motion pins as an input:
  pinMode(CycleIndicatorPin, OUTPUT);
  digitalWrite(CycleIndicatorPin, HIGH);
  // start the serial connection
  Serial.begin(9600);
  // wait to allow serial monitor to open
  delay(500);
  Serial.print("Connecting to Adafruit IO");
  io.connect();
  // wait for a connection
    Serial.println (io.status());
    Serial.print("*!");
    delay(500);
  // attach a message handler for the ISO feed
  iso->onMessage(handleISO);
  // we are connected
  Serial.println();
  Serial.println(io.statusText());
  control->get();
  while(io.mqttStatus() < AIO_CONNECTED) {
    Serial.print(".");
    delay(500);
void loop()
  io.run();
  // check for a reading no more than 200ms.
  if (millis() - CycleIndicatorPin > CycleTime)
    delay (1000);
    // read Data
    counter++;
    if (NotificationControl == 1) {
      Serial.println("Uploading Data*******************");
      output->save(counter);
  digitalWrite(CycleIndicatorPin, LOW);
void handleMessage(AdafruitIO_Data *data) {
  Serial.print("received <- *");
  ReturnStr = data->value();
  Serial.print(ReturnStr);
  Serial.print("*");
  // since we are using the same function to handle
  // messages for two feeds, we can use feedName() in
  // order to find out which feed the message came from.
  if(ReturnStr == "ON")
    Serial.println("ON");
    NotificationControl = 1;
  else
    Serial.println("OFF");
// message handler for the ISO-8601 feed
void handleISO(char *data, uint16_t len) {
  AdafruitTime = String(data);
  Serial.print("ISO Feed: ");
  Serial.println(data);
ahoadley
Re: Grand Central M4 fails to connect using "AdafruitIO_WiFi
by brubell on Tue Mar 10, 2020 11:41 am
Could you modify your code to force the Grand Central configuration and let me know if that works?
    #define SPIWIFI SPI
brubell
by ahoadley on Tue Mar 10, 2020 6:38 pm
I removed my board configuration code and inserted the code you provided and got the same results.
ahoadley
by brubell on Thu Mar 12, 2020 11:41 am
Given this, are you able to run this example: https://github.com/adafruit/Adafruit_MQ ... irlift.ino
Make sure to change the pins here: https://github.com/adafruit/Adafruit_MQ ... ft.ino#L23
to match the configuration you used in the WiFiSSLClient example.
brubell
by ahoadley on Thu Mar 12, 2020 8:35 pm
That code works using WiFiNINA library 1.4.0, which is great. I upgraded to WiFiNINA 1.5.0 to see if it still had that issue and got the following compiler error. I am not sure this is tied to why my Grand Central setup is not able to use the AdafruitIO_WiFi library, but thought it might be a clue.
Arduino: 1.8.12 (Windows 10), Board: "Adafruit Grand Central M4 (SAMD51), Enabled, 120 MHz (standard), Small (-Os) (standard), 50 MHz (standard), Arduino, Off"
C:\D_Drive\Arduino_Adafruit_Versions\adafruitio_secure_airlift_awh\adafruitio_secure_airlift_awh.ino: In function 'void setup()':
adafruitio_secure_airlift_awh:75:10: error: 'class WiFiClass' has no member named 'setPins'
WiFi.setPins(SPIWIFI_SS, SPIWIFI_ACK, ESP32_RESETN, ESP32_GPIO0, &SPIWIFI);
Multiple libraries were found for "WiFiNINA.h"
Used: C:\D_Drive\Arduino_Adafruit_Versions\libraries\WiFiNINA
Not used: C:\D_Drive\Arduino_Adafruit_Versions\libraries\WiFiNINA-master
exit status 1
ahoadley
by brubell on Fri Mar 13, 2020 9:43 am
Are you using the Adafruit fork of the Nina library, or the arduino one?
Please uninstall the Arduino library and install the adafruit one here: https://github.com/adafruit/WiFiNINA
brubell
by ahoadley on Fri Mar 13, 2020 5:30 pm
I removed the Arduino library and added the Adafruit library in your link and then tested the sketch you previously had me run for testing. The Grand Central and the Airlift lite run just fine. I will just ignore the Arduino IDE update advisory.
I still cannot use the Adafruit_IO_WIFI library, which I also updated, on the Grand Central but can run on the Airlift Lite. There seems to be a difference between the two boards that the Adafruit_IO libary is not handling. Can you setup a Grand Central and uses the Adafruit_IO library to see if the problem is in my system or an issue with the Adafruit_IO library.
For reference the parts I am using are part of Order #2256396-7424321996.
ahoadley
by ahoadley on Fri Mar 13, 2020 6:04 pm
Just on a whim I moved the pin assignments to 10, 9, 6 as they are on Airlift Lite. Sadly no change in the results.
ahoadley
by brubell on Tue Mar 17, 2020 11:15 am
After installing the Adafruit Nina-Fw, are you getting the same "adafruitio_secure_airlift_awh:75:10: error: 'class WiFiClass' has no member named 'setPins'" error as before?
brubell
by ahoadley on Tue Mar 17, 2020 12:38 pm
I am getting no compiling errors now for either board. The Metro M4 Airlift Lite board runs successfully, with the following output:
12:11:55.345 ->
12:11:55.382 -> Adafruit IO connected.
12:11:56.497 -> received <- *OFF*OFF
12:11:56.497 -> ISO Feed: 2020-03-17T16:11:55.141Z
12:11:56.532 -> ISO Feed: 2020-03-17T16:11:56.142Z
12:11:57.635 -> ISO Feed: 2020-03-17T16:11:57.142Z
12:11:58.763 -> ISO Feed: 2020-03-17T16:11:58.142Z
The Grand Central has the same repeating output listed earlier.
18:41:58.972 -> *!1
18:41:59.491 -> *!1
The sketch is the original one I included, with the simplified pin assignment section you recommended earlier. I am also using the default pin assignments used on the Metro M4 Airlift Lite board ( 10, 9, 6 ) on the Grand Central with the appropriate wire changes. Thus the same sketch is run on both boards, with only the board designation and com port changed, as appropriate.
ahoadley
by Systembolaget on Sun Apr 12, 2020 1:24 pm
Sorry for "hijacking" this thread, but that seems just like what I'm experiencing with Adafruit's AirLift ESP 32 board connected to provide my set-up with WiFi hookup to Adafruit IO viewtopic.php?f=56&t=164186
The basic WiFiNINA (Adafruit's library based) examples do work and the sketch suggested in your thread https://github.com/adafruit/Adafruit_MQ ... irlift.ino works with my set-up, too, but not the adafruitio_00_publish and any other examples from that example sketch list to connect to Adafruit IO with AirLift boards.
Systembolaget
by ahoadley on Sun Apr 12, 2020 5:10 pm
This does look like the same issue with the AdafruitIO library. Given the difficult time we are living through, I have been just standing by to see if there will be a solution. My trouble shooting has been going in circles and I am stumped. I have even looked at the library and determined that my coding skills are lacking at that level. When their situation allows, I would like Adafruit to duplicate my setup and see if they can duplicate the failure.
ahoadley
by Systembolaget on Thu Apr 16, 2020 6:36 am
Just for reference while awaiting feedback regading AirLift WiFi/Adafruit IO issues.
Arduino IDE - version 1.8.10
SPI.h - comes with Arduino IDE
WiFiNINA (Adafruit flavour) - downloaded from https://github.com/adafruit/WiFiNINA
Adafruit_IO_Arduino - downloaded from https://github.com/adafruit/Adafruit_IO_Arduino
Adafruit_MQTT_Library - downloaded from https://github.com/adafruit/Adafruit_MQTT_Library
Not working adafruitio_00_publish.ino includes config.h which includes AdafruitIO_WiFi.h which includes AdafruitIO_AIRLIFT.h which includes AdafruitIO.h, Adafruit_MQTT.h, Adafruit_MQTT_Client.h, Arduino.h, SPI.h and WiFiNINA.h
Working adafruitio_secure_airlift includes WiFiNINA.h, SPI.h, Adafruit_MQTT.h which includes Arduino.h and Adafruit_MQTT_Client.h which includes Client.h and Adafruit_MQTT.h
Systembolaget
by marsmen on Mon May 11, 2020 3:41 pm
Is there an update to this?
I'm using an Adafruit Metro M4 AIRLIFT Lite with Adafruit IO for school. It is a two quarter course. It worked fine last quarter except that right at the end of the quarter, ~March 30th, the AdafruitIO website was going nuts. I was sending data, an int value, once every second and was being told I was sending too much data. I dropped it to 30 second update, same error. Dropped it to a minute and got the same error. I gave up after a couple hours.
Now this quarter, after updating all the libraries, and have been using the board w/o wifi setting up all the things one sets up just fine. I'm now ready to connect for IoT and send...basically the equivalent of the home_security example.
I'm getting this error when compiling:
In file included from /Users/owner/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/AdafruitIO_WiFi.h:26:0,
from sketch/config.h:19,
from /Users/owner/Documents/Arduino/AirLIFT_FreeRTOS_Projects/MEGR3370-DAQ-Lab2n3/MEGR3370-DAQ-Lab2n3/MEGR3370-DAQ-Lab2n3.ino:38:
/Users/owner/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/wifi/AdafruitIO_AIRLIFT.h: In member function 'virtual void AdafruitIO_AIRLIFT::_connect()':
/Users/owner/Documents/Arduino/libraries/Adafruit_IO_Arduino/src/wifi/AdafruitIO_AIRLIFT.h:161:14: error: 'class WiFiClass' has no member named 'setPins'
WiFi.setPins(_ssPin, _ackPin, _rstPin, _gpio0Pin, _wifi);
exit status 1
Error compiling for board Adafruit Metro M4 AirLift Lite (SAMD51).
I get the same error for all the AdafruitIO examples.
I updated the AdafruitIO_AIRLIFT.h, but compiling still has same issue.
I compiled the adafruit_secure_airlift.ino just fine, but halfway through the install, it did something to my USB port. I switched ports and it uploaded fine.
I'm able to send data to the website and see the steam I setup in my dashboard.
It is just very bizarre that suddenly half of the programs won't be running. And now I need to do additional setup work for SSL?
I keep running into these issues where something has changed and I'm, on average, spending 6-8 hrs troubleshooting down a path and then the solutions I read fail. I hope going through and setting up the SSL isn't one of them. I'm behind on homework due to these glitches(?) where suddenly wifi boards aren't supported or drivers have changed or etc, etc.
I really like this board though!
marsmen
by LagomBra on Mon May 11, 2020 4:39 pm
See viewtopic.php?f=56&t=164725#p811069 and try out the amended version.
LagomBra
