I downloaded and replaced with the updated changes.
It did not fix the issue.
I found the issue.
In WiFiNINA/src/WiFi.h, even though I updated it. It did not actually update the files. I manually removed the folder from the Arduino Library, downloaded the latest from https://github.com/adafruit/WiFiNINA
And put them in the library. That was successful.
Grand Central M4 fails to connect using "AdafruitIO_WiFi.h"
- marsmen
- brubell
- Learn User Page
Re: Grand Central M4 fails to connect using "AdafruitIO_WiFi
Last week we rolled out a patch for the library which may have resolved the issue on the thread. Please update your Adafruit IO Arduino library to 3.6.0 (https://github.com/adafruit/Adafruit_IO ... /tag/3.6.0).
- ahoadley
The patch has solved the problem. Thanks
I am still having problems with my systems locking up at variable connect time ranging from 6 to 36 hours or so. This has happened with both python and Arduino versions. Still trying to figure this one out. My best guest is a random connection issue that either the library or my program can't recover.
- marsmen
I updated everything yesterday. Today, Arduino Library Manager said my updated WiFiNINA was old (ver 1.4.0). It updated to 1.5.0. It quick working.
The time date on the WiFi.h in WiFiNINA of the 1.5.0 is December 30, 2019.
The time date on the WiFi.h in WiFiNINA of the 1.4.0 is February 5, 2020.
I am using the files updated February 5, 2020 without issue. It has the wifi.setpins in is and something that fixes a timeout error alarm in Arduino IDE.
- brubell
- Learn User Page
I do not know what you mean by quit working. Is the library unable to compile? Are you unable to connect to Adafruit IO?marsmen wrote:I updated everything yesterday. Today, Arduino Library Manager said my updated WiFiNINA was old (ver 1.4.0). It updated to 1.5.0. It quick working.
Could you please paste the error you're getting from either the serial monitor or the Arduino IDE?
- marsmen
@brubell
It had the same errors with the wifi.setpins (same error repeated throughout the post) and a timing error.
