subtopic help
subtopic help
by epress on Wed Mar 11, 2020 1:56 pm
Trying to post in via MQTT and having an issue - If I have subtopics, it does not seem to work!
Posting to Mosquitto (using the -v option) I'm subscribed to:
mosquitto_sub -h ipAddress -v -t userId/f/sensors/#
(User ID = Adafruit UserId)
And I see data
userId/f/sensors/RTD/add102 {"ModuleType":"RTD","Reading":23.199,"Address":102,"Name":""}
Then I try to switch over to adafruit, and I see NO data
Interesting, when the sender is just using the topic:
userId/f/sensors
I get the data, with no issue.
What am I doing wrong? Is there a different format for subtopics?
epress
Re: subtopic help
by brubell on Thu Mar 12, 2020 11:28 am
There aren't subtopics in IO like you'd have in a typical MQTT broker. We use grouped feeds which you can pub/sub to through a single MQTT topic.
The topics formats for publishing or subscribing are:
(username)/groups/(group name or key)
(username)/groups/(group name or key)/json
(username)/groups/(group name or key)/csv
For more information, check out the MQTT API page for this topic: https://io.adafruit.com/api/docs/mqtt.html#group-topics
- Brent R.
brubell
cron
