Trying to do an out of band HTTP POST while using io.connect
by klif on Thu Mar 12, 2020 7:39 pm
I have a working Adafruit IO application that establishes an io.connect() session and can receive and send data just fine. Now I'd like to use an my own messaging server that takes a raw HTTP GET request. Since WiFi is already configured by the "io.config()" is there a way that I can add on a call to another HTTP web server to send that put request? I tried using WiFi client but it just wouldn't pick up on the existing WiFi connection. Or at least I didn't know enough to get it to do so. So essentially, with a working io.connect() session I'd like to add something like a WiFiClient connect to a new HTTP server and then issue a GET request for a new URL. I hope this is explained well enough. At a high level I have an ESP8266 connected to Adafruit IO sending and receiving data. At some point I'd like to send an HTTP GET request to a different web server to send an email message. I just can't figure out how to make that second HTTP request.
Any help or pointers are appreciated.
-K
klif
Re: Trying to do an out of band HTTP POST while using io.con
by klif on Sat Mar 14, 2020 6:05 pm
Well I'm kind of answering my own question here. I did manage to get this working, but what I had to do is just include all the ESP8266WiFi headers. Then instantiated a new ESP8266WiFiMulti, WiFi Client and HTTPClient. Essentially creating a complete second wifi client connection. I just couldn't find a way of accessing the WiFi client that was buried in the Adafruit IO. At least this worked but it seems like hitting it with a hammer rather than a scalpel.
klif
by brubell on Tue Mar 17, 2020 11:12 am
Creating a second WiFi client may be best solution here - Adafruit IO Arduino's WiFiClient should be used for Adafruit IO only.
brubell
by INDOOR_GPK on Mon Nov 16, 2020 7:10 am
Hi, same problem here.
Would just make http request through LAN and since Adafruit_IO_Arduino is implemented nothing works....
Can you please share you're workaround code snippet ?
INDOOR_GPK
