Adafruit not receiving data
by Alfredfoby on Fri Mar 13, 2020 4:51 pm
I am using an Arduino mega connected to the SIM 7000A modem, I publish data from the arduino to the adafruit io like pressure values, temperature and other things. It has been working ever since all of a sudden it just stopped working and its not sending data at all to adafruit even though there's connection. I thought it was originally a sim card problem but i checked with hologram and its not, I don't know if something happened to the server or not because I did not change anything to the code or the setup. I have even changed modems and arduinos.
Any insite??
Alfredfoby
Re: Adafruit not receiving data
by adafruit_support_carter on Fri Mar 13, 2020 6:21 pm
What kind of AIO account do you have? Maybe you're hitting a rate limit with the free account? Although that should have happened a while ago.
by Alfredfoby on Fri Mar 13, 2020 7:05 pm
adafruit_support_carter wrote:What kind of AIO account do you have? Maybe you're hitting a rate limit with the free account? Although that should have happened a while ago.
I actually have an IO+ account so I don't think I hit a limit, it was also working maybe 6 days ago and suddenly stopped even when nothing was changed at all, sim cards have been swapped, boards too, which makes me believe its a problem from adafruit
Alfredfoby
by adafruit_support_carter on Fri Mar 13, 2020 8:34 pm
What if you try the basic pub example from the library?
https://github.com/adafruit/Adafruit_IO ... 00_publish
Does that also not seem to post?
by Alfredfoby on Fri Mar 13, 2020 8:39 pm
adafruit_support_carter wrote:What if you try the basic pub example from the library?
I will try that as soon as I'm with my Arduino,
I have three units, two of those units are constantly sending data as they should, but on the third one it suddenly just stopped and all three units have the same exact code
So I don't know what could be causing this
Alfredfoby
by OneH2 on Sat Mar 14, 2020 9:14 am
I tried it and even that one doesn't work, I haven't changed anything in the code or anything so I don't know, Please help.
OneH2
by Alfredfoby on Sat Mar 14, 2020 11:37 am
I believe something may have altered my account or something because it just suddenly stopped when nothing was changed
Alfredfoby
by adafruit_support_carter on Sat Mar 14, 2020 11:56 am
But to only the one unit? The others are still posting OK?
by Alfredfoby on Sat Mar 14, 2020 12:06 pm
adafruit_support_carter wrote:But to only the one unit? The others are still posting OK?
Yes the others are still posting OK, these units haven't been altered in a long time, all have the same code, and are still running fine, one of them just isn't receiving data on adafruit
Alfredfoby
by adafruit_support_carter on Sat Mar 14, 2020 1:46 pm
Do you get any errors when running the basic example sketch?
by Alfredfoby on Sat Mar 14, 2020 1:48 pm
adafruit_support_carter wrote:Do you get any errors when running the basic example sketch?
No I don't, I just don't see anything being published on adafruit io
Alfredfoby
by adafruit_support_carter on Sat Mar 14, 2020 3:12 pm
And the serial prints continue to output?
https://github.com/adafruit/Adafruit_IO ... sh.ino#L62
Try capturing the return from the publish call and printing it:
https://github.com/adafruit/Adafruit_IO ... sh.ino#L64
