Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more.
How do I populate the lat long values with fixed data in my
by Antidote on Mon Mar 16, 2020 1:42 am
I have some feeds for a BME260 configured and all working well via an ESP32. I plan to have numerous setup over the city and would like a map in my dashboard to show where they are..
Is it possible to send in fixed lat,long data with my feeds so that they will appear on the map block in my dashboard?
How can I populate those location columns with a fixed value?
my output is created within Arduino ide using a mashup of the BME sample code and adafrui.io feeds
void sendValues() {
    temperature->save(bme.readTemperature());
    humidity->save(bme.readHumidity());
    air_pressure->save(bme.readPressure() / 100.0F);
Antidote
Re: How do I populate the lat long values with fixed data in
by dastels on Mon Mar 16, 2020 10:26 am
Try adding lat and lon key-value pairs to the payload you send to AdafruitIO. For example (from my environmental sensor project guide: https://learn.adafruit.com/remote-iot-environmental-sensor)
{'value' : 0, 'lat' : gps_interface.latitude, 'lon' : gps_interface.longitude, 'created_at' : ''}
dastels
by brubell on Tue Mar 17, 2020 10:45 am
Hi antidote,
If you're using the Adafruit IO Arduino library, you can send locational data by including the location metadata with the value you send to Adafruit IO:
    location->save(value, lat, lon, ele);
For example: Sending the location to the temperature feed would look like:
    temperature->save(bme.readTemperature(), lat, lon, ele);
Here's a full example:
https://github.com/adafruit/Adafruit_IO ... cation.ino
brubell
