aio.send(image)
aio.send(image)
by groznigaspr on Tue Mar 17, 2020 1:06 pm
i am having trouble with uploading image into the feed. i capture image on raspberry camera and lower it's quality and then encode it. i try to send it withaio.send and get following error. i found out that picture is encoded correctly(becasue i dragged the same picture into the feed and cheched its value it's the same as encoded picture. I tried to decode that image and it was displayed correctly)
i am getting error
File "uplodepicture.py", line 31, in <module>
aio.send(picam_feed,value)
File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 154, in send_data
return self.create_data(feed, payload)
File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 254, in create_data
return Data.from_dict(self._post(path, data._asdict()))
File "/home/pi/.local/lib/python3.5/site-packages/Adafruit_IO/client.py", line 126, in _post
data=json.dumps(data))
File "/usr/lib/python3.5/json/__init__.py", line 230, in dumps
return _default_encoder.encode(obj)
File "/usr/lib/python3.5/json/encoder.py", line 198, in encode
chunks = self.iterencode(o, _one_shot=True)
File "/usr/lib/python3.5/json/encoder.py", line 256, in iterencode
return _iterencode(o, 0)
File "/usr/lib/python3.5/json/encoder.py", line 179, in default
raise TypeError(repr(o) + " is not JSON serializable")
TypeError: b'/9j/4AAQSkZJRgABAQAAAQABAAD........ a lot of text.........j/2Q==' is not JSON serializable
CODE:
import io
from Adafruit_IO import*
from PIL import Image
import base64
import picamera
aio = Client("xxxxxxxxxxx", "xxxxxxxxxxxxxxx")
camera=picamera.PiCamera()
picam_feed=aio.feeds('picam')
stream = io.BytesIO()
camera.capture(stream, format='jpeg', resize=(800, 600))
stream.seek(0)
print('> optimizing')
image = Image.open(stream, 'r')
optim_stream = io.BytesIO()
image.save(optim_stream, format='jpeg', quality=70, optimize=True)
optim_stream.seek(0)
print('> converting')
value = base64.b64encode(optim_stream.read())
if len(value) > 102400:
print ("image is too big!")
time.sleep(2)
groznigaspr
Re: aio.send(image)
by brubell on Thu Mar 19, 2020 10:19 am
JSON can't handle raw bytes, that why you're getting this error. Could you try converting the base64 bytes object into a string for the call to aio.send:
b64_string = value.decode('utf-8')
brubell
