Clue display blank
Clue display blank
by waredgo on Fri Mar 20, 2020 11:02 am
My CLUE display remain blank, but backlit. The unit takes new code, but no output is generated.
waredgo
Re: Clue display blank
by dastels on Fri Mar 20, 2020 1:38 pm
"Takes new code" ... what language?
If CircuitPython, is it running? Can you get into the REPL?
If C++, does output to Serial work?
dastels
by waredgo on Fri Mar 20, 2020 2:10 pm
Trying to upload sketches through the Arduino app. Everything goes well with coms to the board, just nothing happens after reboot.
waredgo
by dastels on Fri Mar 20, 2020 2:13 pm
I'm not clear, are you getting output from Serial.print()?
dastels
by waredgo on Fri Mar 20, 2020 4:18 pm
Yes, I am getting a serial output to a certain extant.
For example, I uploaded the barometric pressure sketch which compiled and u;loaded without error .On the serial monitor, I can see the output for about 5 seconds and then nothing.
There is no output on the LCD screen whatsoever. If I reset, output on the serial monitor continue for a few seconds, then no output.
waredgo
by dastels on Fri Mar 20, 2020 4:48 pm
Hmm.. Does your code do anything with the display?
Did you try the sensor test?
https://learn.adafruit.com/adafruit-clue/arduino-test
Or the GIF test?
https://learn.adafruit.com/adafruit-clue/animated-gif-player
dastels
by waredgo on Fri Mar 20, 2020 6:47 pm
Ah, the sensor check sketch got it working again.
Weird.
waredgo
