Adafruit Industries, Essential service and business: NYC – Executive Order 202.6 - Read more.
throttling issue in esp8266
by Roshan_2409 on Sat Mar 21, 2020 2:17 am
i have 5 digital sensors connected to a nodemcu esp8266 board. In adafruit I have 5 feeds( 1 for each sensor) under 1 project. When i run the system it shows throttling limit reached. How much delay should I add at the end of the code to prevent throttling? currently i have a delay of 8 secs.
Roshan_2409
Re: throttling issue in esp8266
by brubell on Tue Mar 24, 2020 10:12 am
Hi Roshan_2409,
If you're using Adafruit IO Free, you can send or receive 30 data points per minute. If you're using Adafruit IO Plus, you can send or receive 60 data points per minute. These limits actions/feeds on your account.
It looks like you're sending 37-38 data points per minute. You can either increase the delay to 10 seconds or upgrade to Adafruit IO Plus.
brubell
