Last Value Feed
Last Value Feed
by guillaumearnx on Sat Mar 21, 2020 12:02 pm
Hello, how can I get the last value from a feed when ESP8266 starts because
if (!strcmp((char*)onoff.lastread, "**"))
only updates when I send a new value to the feed
guillaumearnx
Re: Last Value Feed
by brubell on Tue Mar 24, 2020 10:05 am
Hi, to get a value from the feed, you'll want to use the */get topic.
If you’re using the Adafruit IO Arduino library, you can add /get support to your project in one line of code:
 feedName->get();
Code for the Adafruit IO Arduino library can be found here: https://github.com/adafruit/Adafruit_IO ... d_read.ino
If you're using another library, we have a page in the Adafruit IO MQTT API documentation about using the /get topic: https://io.adafruit.com/api/docs/mqtt.h ... -get-topic
Let me know if you need help or get stuck anywhere.
brubell
Re: Last Value Feed
by guillaumearnx on Tue Mar 24, 2020 11:42 am
Hi, I've tried to install the io library but when i want to upload on ESP8266, i've an error
guillaumearnx
Re: Last Value Feed
by brubell on Wed Mar 25, 2020 12:46 pm
Could you post your entire code in
[code] tags
and the full error output below?
brubell
Re: Last Value Feed
by guillaumearnx on Wed Mar 25, 2020 1:00 pm
#include <AdafruitIO.h>
#include <AdafruitIO_Dashboard.h>
#include <AdafruitIO_Data.h>
#include <AdafruitIO_Definitions.h>
#include <AdafruitIO_Ethernet.h>
#include <AdafruitIO_Feed.h>
#include <AdafruitIO_FONA.h>
#include <AdafruitIO_Group.h>
#include <AdafruitIO_MQTT.h>
#include <AdafruitIO_Time.h>
#include <AdafruitIO_WiFi.h>
#include <ESP8266WiFi.h>
#include "Adafruit_MQTT.h"
#include "Adafruit_MQTT_Client.h"
#define WIFI_SSID "**"
#define WIFI_PASS "**"
#define MQTT_SERV "io.adafruit.com"
#define MQTT_PORT 1883
#define MQTT_NAME "**"
#define MQTT_PASS "**"
int led = D0;
const char* deviceName = "ESP-TEST";
io.connect();
WiFiClient client;
Adafruit_MQTT_Client mqtt(&client, MQTT_SERV, MQTT_PORT, MQTT_NAME, MQTT_PASS);
Adafruit_MQTT_Subscribe onoff = Adafruit_MQTT_Subscribe(&mqtt, MQTT_NAME "/f/test");
void setup()
  Serial.begin(9600);
  pinMode(LED_BUILTIN, OUTPUT);
  pinMode(led, OUTPUT);
  WiFi.hostname(deviceName);
  WiFi.begin(WIFI_SSID, WIFI_PASS);
  WiFi.mode(WIFI_STA);
  while (WiFi.status() != WL_CONNECTED) {
    delay(500);
    Serial.print(".");}
  digitalWrite(LED_BUILTIN, HIGH);
  Serial.println("OK!");
  mqtt.subscribe(&onoff);
void loop()
  MQTT_connect();
  Adafruit_MQTT_Subscribe * subscription;
  while ((subscription = mqtt.readSubscription(5000)))
    onoff->get();
    if (subscription == &onoff){
      Serial.print("onoff: ");
      Serial.println((char*) onoff.lastread);
      if (!strcmp((char*) onoff.lastread, "1")){digitalWrite(led, HIGH);}
      else if (!strcmp((char*) onoff.lastread, "0")){digitalWrite(led, LOW);}
void MQTT_connect()
  if (mqtt.connected() && mqtt.ping())
    return;
  int8_t ret;
  mqtt.disconnect();
  Serial.print("Connecting to MQTT... ");
  uint8_t retries = 3;
  while ((ret = mqtt.connect()) != 0)
    Serial.println(mqtt.connectErrorString(ret));
    Serial.println("Retrying MQTT connection in 5 seconds...");
    mqtt.disconnect();
    delay(5000);
    retries--;
    if (retries == 0)
      ESP.reset();
  Serial.println("MQTT Connected!");
In file included from C:\Users\arnou\Desktop\test\test.ino:1:0:
Multiple libraries were found for "AdafruitIO.h"
D:\Arduino\libraries\Adafruit_IO_Arduino\src/AdafruitIO.h:27:31: fatal error: ArduinoHttpClient.h: No such file or directory
Used: D:\Arduino\libraries\Adafruit_IO_Arduino
#include "ArduinoHttpClient.h"
Not used: D:\Arduino\libraries\Adafruit_IO_Arduino-master
compilation terminated.
exit status 1
Error compiling for board NodeMCU 1.0 (ESP-12E Module)
guillaumearnx
