Need Some Help
Need Some Help
by shaseeb692 on Tue Mar 24, 2020 7:34 pm
Can someone tell me about 10feed ?
    What are 10feeds meaning?
    What is the meaning of trigger every 15 minutes?
shaseeb692
Re: Need Some Help
by dastels on Wed Mar 25, 2020 10:27 am
Feeds are data streams. A place on AdafruitIO here you put a series of data packets that have the same format. E.g. temperature readings could be one feed, humidity readings could be another.
In the free plan you get to have 10 of them.
Triggers are things you can set up that look at incoming data (in a feed) and make some decision on whether or not to perform some action (e.g. posting data to another feed).
E.g. if a temperature reading is above 40C, post True to the fan control feed.
The free plan limits trigger use to once every 15 minutes (once a trigger fires, it's 15 minutes before it or another trigger can fire).
There are many guides on using AdafruitIO: https://learn.adafruit.com/search?q=adafruit%20IO
dastels
