Trouble connecting --2nd time
by Fibbermcg on Sat Apr 11, 2020 12:55 pm
Adafruit IO Temperature & Humidity Example-#15
Had this running last year. Went to revise SSID and Pswd to a remote router, and now cannot get it to connect to old or new router. Serial stops at ....... in the code?
What am I missing ?
Also this was the last line in the upload info---
Leaving...
Hard resetting via RTS pin...
Is this a good statement?
Bill
Fibbermcg
Re: Trouble connecting --2nd time
by brubell on Wed Apr 15, 2020 1:08 pm
Are you using the latest versions of the following libraries Adafruit IO Arduino, Arduino JSON, Arduino HTTP Library, Adafruit MQTT Library
What hardware are you using?
brubell
by Fibbermcg on Wed Apr 15, 2020 11:05 pm
I thought I updated the libraries, will recheck. Hardware same as a year ago. Adafruit Huzzah esp8266 with a #am2302 temp humidity sensor.
Fibbermcg
