Black Lives Matter - Action and Equality.
group->save() reboots ESP32
by crcibernetica on Tue Apr 14, 2020 10:17 am
Adafruit IO Library example adafruitio_11_group_pub (no modifications) crashes immediately after the group->save() command.
Am using the generic ESP32 (DOIT ESP32 DEVKIT V1). So far all other examples work without any problems. Just the group-->save() causes the reboot.
Connecting to Adafruit IO.
Adafruit IO connected.
sending example.count-1 -> 0
sending example.count-2 -> 0
Guru Meditation Error: Core  1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC      : 0x400d1e80  PS      : 0x00060830  A0      : 0x800d1f28  A1      : 0x3ffb1ee0
A2      : 0xfefefefe  A3      : 0x3ffd7b38  A4      : 0x00000000  A5      : 0x00000000
A6      : 0x00000000  A7      : 0x00000000  A8      : 0x800d1cdc  A9      : 0x3ffb1eb0
A10     : 0x3ffd7b38  A11     : 0x7fffffff  A12     : 0x00000000  A13     : 0x00000000
A14     : 0x00000000  A15     : 0x00000000  SAR     : 0x0000000a  EXCCAUSE: 0x0000001c
EXCVADDR: 0xfefefefe  LBEG    : 0x400012c5  LEND    : 0x400012d5  LCOUNT  : 0xfffffff7
Backtrace: 0x400d1e80:0x3ffb1ee0 0x400d1f25:0x3ffb1f00 0x400d25e4:0x3ffb1f50 0x400d1b6f:0x3ffb1f70 0x400d17fe:0x3ffb1f90 0x400d5151:0x3ffb1fb0 0x40088b9d:0x3ffb1fd0
Rebooting...
ets Jun  8 2016 00:22:57
rst:0xc (SW_CPU_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
The stack trace decodes to the following:
PC: 0x400d1e80: AdafruitIO_Group::call(AdafruitIO_Data*) at C:\Users\laserman\Documents\Arduino\libraries\Adafruit_IO_Arduino\src\AdafruitIO_Group.cpp line 348
Decoding stack results
0x400d1f25: AdafruitIO_Group::subCallback(char*, unsigned short) at C:\Users\laserman\Documents\Arduino\libraries\Adafruit_IO_Arduino\src\AdafruitIO_Group.cpp line 399
0x400d25e4: Adafruit_MQTT::processPackets(short) at C:\Users\laserman\Documents\Arduino\libraries\Adafruit_MQTT_Library\Adafruit_MQTT.cpp line 443
0x400d1b6f: AdafruitIO::run(unsigned short, bool) at C:\Users\laserman\Documents\Arduino\libraries\Adafruit_IO_Arduino\src\AdafruitIO.cpp line 340
0x400d17fe: loop() at C:\Users\laserman\AppData\Local\Temp\arduino_modified_sketch_417427/adafruitio_11_group_pub.ino line 58
0x400d5151: loopTask(void*) at C:\Users\laserman\AppData\Local\Arduino15\packages\esp32\hardware\esp32\1.0.4\cores\esp32\main.cpp line 19
0x40088b9d: vPortTaskWrapper at /home/runner/work/esp32-arduino-lib-builder/esp32-arduino-lib-builder/esp-idf/components/freertos/port.c line 143
Any ideas? I upgraded the Arduino IDE to 1.8.12 (1.8.10 had the same problem), all the board definitions and libraries.
crcibernetica
Re: group->save() reboots ESP32
by brubell on Wed Apr 15, 2020 12:24 pm
This issue is tracked and being looked at over on the Adafruit IO Arduino repository: https://github.com/adafruit/Adafruit_IO ... issues/114
brubell
by crcibernetica on Tue Apr 21, 2020 9:02 am
brubell wrote:This issue is tracked and being looked at over on the Adafruit IO Arduino repository: https://github.com/adafruit/Adafruit_IO ... issues/114
Thanks, I saw your patch and applied it. It works for me! Hope to see the library updated soon.
crcibernetica
by brubell on Tue Apr 21, 2020 9:37 am
It'll get merged in soon, could you comment on the pull request that it worked for you? Thanks!
brubell
by crcibernetica on Tue Apr 21, 2020 10:11 am
brubell wrote:It'll get merged in soon, could you comment on the pull request that it worked for you? Thanks!
Done. Thank you!
crcibernetica
by brubell on Tue Apr 21, 2020 10:33 am
Thanks - release time :)
brubell
