Black Lives Matter - Action and Equality.
Adafruit.io + CircuitPython + Ethernet Featherwing
by proshow on Wed Apr 15, 2020 4:05 pm
I am trying to get the Ethernet Featherwing and a M4 Express working with Adafruit.io. From the message I get it looks like the adafruit_io library only works with wifi.
File "code.py", line 71, in <module>
File "adafruit_io/adafruit_io.py", line 465, in __init__
TypeError: This library requires a WiFiManager object.
Thanks.
proshow
Re: Adafruit.io + CircuitPython + Ethernet Featherwing
by jerryn on Wed Apr 15, 2020 5:02 pm
jerryn
by proshow on Wed Apr 15, 2020 5:11 pm
Fantastic. Thanks!
proshow
by brubell on Sat Apr 18, 2020 9:56 am
You'll need to update to the latest version of Adafruit IO for CircuitPython.
An example of using the Adafruit IO CircuitPython MQTT library with Ethernet is here: https://github.com/adafruit/Adafruit_Ci ... est_eth.py
brubell
