Black Lives Matter - Action and Equality.
MPU6050 data to AdafruitIO using Adafruits please help
by Pwelco on Sat Apr 18, 2020 3:41 pm
sketch MPU6050-AdafruitIO 15APR20 0945AM.txt
the code here is pasted into notepad
(4.48 KiB) Downloaded 9 times
Just to be clear, I am not a programmer but know enough to be dangerous and have been successful in my other Arduino projects.
What I am using:
Adafruit Feather HUZZAH with ESP8266 WiFi
mpu6050 / GY-521
Adafruit IO
On this project I am stumped (not hard to do...) with the code for uploading data from a MPU6050 to Adafruit IO. I have done hours/days/weeks of web searches trying to find the right code to help get movement data from an MPU6050 or GY-521. What I want to graph is a single feed that tells what day/time the mpu6050 was moved and how much. After that add up to 5 feeds from several say six mpu6050's. Baby steps.
What I have done is started with both the Adafruitio_08_analog_in and the Adafruit mpu6050_unifiedsensors example sketches. I just cant figure it out. I have a dashboard with a feed and graph block.
For the code attached I am just at first trying to see temperature from the mpu6050. You can laugh when you see my butchered code. I won't mind :)
I am getting data to the graph block but its flatline or rather a 1 when I look at the Arduino serial monitor.
Please be positive and constructive with your questions and comments,
Thx! Pwelco
Pwelco
Re: MPU6050 data to AdafruitIO using Adafruits please help
by Pwelco on Mon Apr 20, 2020 12:04 pm
After staring at this for a few more hours I at least have the temperature working now, see attached code. Just need to get the accel and gyro data figured out.
sketch MPU6050-AdafruitIO 20APR20.txt
(3.17 KiB) Downloaded 7 times
Pwelco
by Pwelco on Sun Apr 26, 2020 5:03 pm
Finally got it working!!
Pwelco
cron
