Black Lives Matter - Action and Equality.
Row Limit Python data retrirval
by bayesp on Mon Apr 20, 2020 1:50 pm
HI
Is there a row limit when fetching data using the Adafruit io python library? If I pull back a feed to an array and then from th array to a dataframe, I only get 1000 rows?
bayesp
Re: Row Limit Python data retrirval
by brubell on Tue Apr 21, 2020 9:40 am
Could you please post your python code file along with an example of the output? Thanks
brubell
by bayesp on Tue Apr 21, 2020 11:50 am
Hi here is the code with my credentials redacted:
!pip install adafruit-io
from Adafruit_IO import Client
aio = Client('xxxxxxxx','xxxxxxxx')
data = aio.data('enviro')
import pandas as pd
df= pd.DataFrame(data)
import altair as alt
df.sort_values(by=['created_epoch'], inplace=True, ascending=False)
df['created_at'] = df['created_at'].astype('datetime64[ns]')
source = df
alt.Chart(source).mark_line().encode(
    x='created_at:T',
    y='value:Q'
df.head()
df.head
created_epoch created_at updated_at value completed_at feed_id expiration position id lat lon ele
0 1587483858 2020-04-21 15:44:18 None 21.84 None 1356732 2020-05-21T15:44:18Z None 0EE0K1TPK75WG22VC91PCY8MS3 None None None
1 1587483847 2020-04-21 15:44:07 None 21.84 None 1356732 2020-05-21T15:44:07Z None 0EE0K1QAEBPZT8Z5CMP53ST4YD None None None
2 1587483836 2020-04-21 15:43:56 None 21.84 None 1356732 2020-05-21T15:43:56Z None 0EE0K1KZ1PW8TQKKEKBQBX8BDD None None None
3 1587483825 2020-04-21 15:43:45 None 21.84 None 1356732 2020-05-21T15:43:45Z None 0EE0K1GK62VQ788G03R5NVGRQ1 None None None
4 1587483814 2020-04-21 15:43:34 None 21.84 None 1356732 2020-05-21T15:43:34Z None 0EE0K1D7V1EEG7KBQ3MEY9F8B6 None None None
df.describe
created_epoch feed_id
count 1.000000e+03 1000.0
mean 1.587478e+09 1356732.0
std 3.183911e+03 0.0
min 1.587473e+09 1356732.0
25% 1.587476e+09 1356732.0
50% 1.587478e+09 1356732.0
75% 1.587481e+09 1356732.0
max 1.587484e+09 1356732.0
bayesp
by brubell on Wed Apr 29, 2020 12:33 pm
I'm not sure why you're hitting a row limit. You could try downloading the feed as a CSV or JSON, and parse through it:
brubell
