Black Lives Matter - Action and Equality.
Device Does not changes state with java Java program, but ok
by andrebarone on Tue Apr 21, 2020 8:41 pm
Hi Guys,
first of all I'd like to say that I have searched in the forum for a similar question, and my apologies if is there and I couldn't reached.
So,
my problem is that I made an small publishing program to change the value of a Feed on the dashboard using Java/PAHO, and therefore access the state of a LED on my ESP8266 :
 public static void main(String[] args) {
   String topic = <MyUserName>/feeds/lednodemcu";
   String content = "OFF";
   int qos = 1;
   String broker = "tcp://io.adafruit.com";
   String clientId =  "<MyUserName>";
   String password =  "<MyKey>";
   MemoryPersistence persistence = new MemoryPersistence();
   try {
           MqttClient sampleClient = new MqttClient(broker, clientId, persistence);
           MqttConnectOptions connOpts = new MqttConnectOptions();
           connOpts.setMqttVersion(MqttConnectOptions.MQTT_VERSION_3_1);
           connOpts.setCleanSession(false);
           connOpts.setPassword(password.toCharArray());
           connOpts.setUserName(clientId);
           System.out.println("Connecting to broker: "+broker);
           sampleClient.connect(connOpts);
           System.out.println("Connected");
           System.out.println("Publishing message: "+content);
           MqttMessage message = new MqttMessage(content.getBytes());
           message.setQos(1);
           sampleClient.publish(topic, message);
           System.out.println("Message published");
           sampleClient.disconnect();
           System.out.println("Disconnected");
           System.exit(0);
   } catch (MqttException e) {
     e.printStackTrace();
I see the Feed state changing, bu Nothing happens at de ESP8266
What intrigues me is that I publish a simillar stuf using mosquitto, and work as expected, that is , both LED on my ESP8266 and Feed on Dashboard changes:
mosquitto_pub -h io.adafruit.com -p 1883 -u '<MyUserName>' -P '<MyKey>' -t '<MyUserName>/feeds/lednodemcu' -m 'OFF'
Could somebody give me any clue?
andrebarone
Re: Device Does not changes state with java Java program, bu
by brubell on Wed Apr 29, 2020 12:48 pm
Navigate to http://io.adafruit.com/monitor and then try sending data to the feed. Do you see any errors on this page?
brubell
by andrebarone on Wed Apr 29, 2020 8:25 pm
Hi @Brubell,
Thnaks for replaying.
No errors appear on monitor, but some weird behavior.
When using Mosquitto, I can see 1 Connect and 1 Disconnect for each publishing request:
For the java application, it does 1 connect, 2 disconnects and 1 connect again:
So, I think I will review the code, although it is a pretty Straight Connect - Publish-Disconnect using Paho Library and MQTT version 3.1
andrebarone
by andrebarone on Wed Apr 29, 2020 8:39 pm
Let me give an update.
I fixed the Problem.
I changed the ClientId on (String serverURI, String clientId, MqttClientPersistence persistence)class.
andrebarone
