Black Lives Matter - Action and Equality.
Combine accelerometer data output to one feed?
by Pwelco on Mon Apr 27, 2020 6:43 pm
I am using an mpu6050 (GY-521) accel/gyro/temp board to detect movement of a person with it strapped to them. I only want to detect that they moved, so I don't really care about which direction etc... Is there a way in Arduino code to combine X,Y,Z accel data so that I only need one feed? Meaning did they move or not. The issue I have is wanting to see real time data without having to delay 5 seconds since I am sending 6 feeds. I am getting the Throttling Error: Exceeded the limit of Adafruit.
I have searched the forums and not found a solution to my issue. I have an IO+ account so 60 data points per minute. If I had one feed I would think I could get down to once per second receiving that feed/data?
Pwelco
Re: Combine accelerometer data output to one feed?
by adafruit_support_bill on Mon Apr 27, 2020 7:03 pm
To combine the X, Y and Z to get the total magnitude independent of direction:
sqrt((x*x) + (y*y) + (z*z));
by Pwelco on Mon Apr 27, 2020 7:49 pm
Thank you!
I'm just a beginner so not sure how to use it. I will play around with it and see if I can figure it out.
Pwelco
