Black Lives Matter - Action and Equality.
AIO CLIENT ERROR HANDLING
by kcweedblog on Wed Apr 29, 2020 10:25 am
I am having some problems with an AIO Raspberry Pi. I used one of the demo scripts and adjusted for my sensor a Si7024. Works well until the WiFi falls offline. The Pi is in a outdoor greenhouse, so connection is mostly stable... Able to VNC with the occasional drop. But every 3-5 minutes AIO fails and the script crashes. I only need to poll the device once a minute or maybe even once every 5 minutes. We are just tracking grow cycles. In my limited knowledge I was thinking there could be a way to error handle the connection loss or maybe even Stop and Restart the script every 5-30 minutes just to keep data flowing even if a gap of Wifi coverage happens. Cron job? In code?
# import standard python modules.
import time
import board
import busio
import adafruit_si7021
# import adafruit dht library.
#import Adafruit_DHT
# import Adafruit IO REST client.
from Adafruit_IO import Client, Feed
# Delay in-between sensor readings, in seconds.
DHT_READ_TIMEOUT = 5
# Pin connected to DHT22 data pin
DHT_DATA_PIN = 26
# Create library object using our Bus I2C port
i2c = busio.I2C(board.SCL, board.SDA)
sensor = adafruit_si7021.SI7021(i2c)
# Set to your Adafruit IO key.
# Remember, your key is a secret,
# so make sure not to publish it when you publish this code!
ADAFRUIT_IO_KEY = ''
# Set to your Adafruit IO username.
# (go to https://accounts.adafruit.com to find your username).
ADAFRUIT_IO_USERNAME = 'kcweedblog'
# Create an instance of the REST client.
aio = Client(ADAFRUIT_IO_USERNAME, ADAFRUIT_IO_KEY)
# Set up Adafruit IO Feeds.
temperature_feed = aio.feeds('temperature')
humidity_feed = aio.feeds('humidity')
# Set up DHT22 Sensor.
#dht22_sensor = Adafruit_DHT.DHT22
while True:
    tempsi = ((sensor.temperature) * 1.8 + 32)
    tempF = float("{0:.2f}".format(tempsi))
    humidsi = (sensor.relative_humidity)
    humidP = float("{0:.2f}".format(humidsi))
    # humidity, temperature = Adafruit_DHT.read_retry(dht22_sensor, DHT_DATA_PIN)
    if humidsi is not None and tempsi is not None:
        print('Temp={0:0.1f}*C Humidity={1:0.1f}%'.format(tempsi, humidsi))
        # Send humidity and temperature feeds to Adafruit IO
        temperature = '%.2f'%(tempF)
        humidity = '%.2f'%(humidP)
        aio.send(temperature_feed.key, str(temperature))
        aio.send(humidity_feed.key, str(humidity))
    else:
        print('Failed to get Si7024 Reading, trying again in ', DHT_READ_TIMEOUT, 'seconds')
    # Timeout to avoid flooding Adafruit IO
    time.sleep(DHT_READ_TIMEOUT)
kcweedblog
Re: AIO CLIENT ERROR HANDLING
by brubell on Wed Apr 29, 2020 12:35 pm
Do you have an example of the error you get when you lose WiFi connection? Could you please copy and paste it below, thanks
brubell
