Black Lives Matter - Action and Equality.
frequent offline event
by cbfraser on Wed Apr 29, 2020 11:50 am
I have a simple client -ESP8266 LUA-using MQTT subscribing to a single feed. It works well but I notice it goes offline about once per minute with no data coming in on the feed and no other code being executed.
I catch this with mqtt:on('offline'.... to redo the connection. The reconnect is always successful, and reads when there is data are correct. But data might be missed during offline/connection blip. Is this frequent offline event to be expected? Unit has strong WIFI signal.
cbfraser
Re: frequent offline event
by brubell on Wed Apr 29, 2020 12:10 pm
If you're using MQTT, you may want to add a add a frequent PING to your LUA/MQTT Client. The client may have a keep-alive interval, try increasing it.
for more information: http://www.steves-internet-guide.com/mq ... y-example/
brubell
by cbfraser on Thu Apr 30, 2020 9:37 pm
I have changed keep alive on the client to 30
mqtt = mqtt.Client('esp8266', 30, username, aioKey)
and ping by publishing to the feed every 30 seconds
fairly consistent offline event every 60 seconds
with "pings" inbetween - see below
also fyi - receiving time/seconds
any other suggestions?
2020/4/30 18:29:31 offline
2020/4/30 18:29:31 connected
# of connections: 11
topic: cbfraser/feeds/garage.garage
topic: time/seconds
topic: cbfraser/errors
subscribe success
subscribe success
subscribe success
2020/4/30 18:29:33: ping sent!
data in: ping
data out: ping
2020/4/30 18:30:3: ping sent!
data in: ping
data out: ping
2020/4/30 18:30:31 offline
cbfraser
by brubell on Fri May 01, 2020 9:36 am
Could you try pinging the server more frequently than every 30sec, maybe ever 10sec?
When you visit your feed monitor page (http://io.adafruit.com/monitor), do feeds disconnect immediately after subscribing to them, or after you publish data to them?
brubell
by cbfraser on Fri May 01, 2020 11:11 am
ping (posting data) every 10 seconds - still regular disconnect every 60 seconds
disconnect not in sync with posting
monitor pages shows connect/disconnect trail and ping data
2020/5/1 7:53:53 offline
2020/5/1 7:53:53 connected
# of connections: 2
topic: time/seconds
subscribe success
subscribe success
subscribe success
2020/5/1 7:53:58: ping sent!
data in: ping
data out: ping
2020/5/1 7:54:8: ping sent!
data in: ping
data out: ping
2020/5/1 7:54:18: ping sent!
data in: ping
data out: ping
2020/5/1 7:54:28: ping sent!
data in: ping
data out: ping
2020/5/1 7:54:38: ping sent!
data in: ping
data out: ping
2020/5/1 7:54:48: ping sent!
data in: ping
data out: ping
2020/5/1 7:54:54 offline
2020/5/1 7:54:54 connected
cbfraser
by cbfraser on Fri May 01, 2020 12:59 pm
and if I strip out subscriptions to time and errors - just the one feed
with no publishing and no other data posted by other clients -
still nice & regular offline/connect about every 60 seconds.....
anything else to try to isolate problem?
thanks
cbfraser
by brubell on Mon May 04, 2020 9:51 am
Could you try rebooting your router?
Also - try setting the pings to every 29sec.
brubell
by cbfraser on Sun May 17, 2020 2:02 pm
rebooted router
publishing data to a subscrbied feed every 10 seconds
subscribed to time/seconds - so receiving every second
keepalive 10 seconds
disconnect very regular 60 seconds
and switch internet connecto to mobile data so router not involved - same behavior
arduino code doing similar subscription to time/seconds - doesn't have problem
so must be a lua /esp8266 issue... I'll just have to work around
thanks for the help
cbfraser
