Black Lives Matter - Action and Equality.
Fona Feed suddenly stopped logging data after I upgraded to
by Ewbroberg on Thu Apr 30, 2020 11:40 am
I have three sensors all logging to different feeds. I had it working on one and upgraded my account to a paid account so I could add more feeds. I added the feeds but now none of my three sensors will log to their feeds. I checked the Feed Keys, Feed names, and IO code. I can see my sensors connecting and disconnecting in the IO monitor.
Regards,
Erik Broberg
Ewbroberg
Re: Fona Feed suddenly stopped logging data after I upgraded
by Ewbroberg on Thu Apr 30, 2020 5:36 pm
I am attaching the the Debug information from my application
Ewbroberg
by Ewbroberg on Thu Apr 30, 2020 5:39 pm
And What I see from the Profile Monitor in IO.
Thanks for any help on this,
Erik
Ewbroberg
by Ewbroberg on Thu Apr 30, 2020 5:45 pm
And Finally my MQTT code as I have it. Note the long delays between sending data was just to see if that would help.
Ewbroberg
by Ewbroberg on Thu Apr 30, 2020 5:46 pm
And the connection code ...
Ewbroberg
by Ewbroberg on Thu Apr 30, 2020 5:49 pm
and finally an image of one of my feeds, they are all very similar just differ by sensor reading and S#
Ewbroberg
by brubell on Fri May 01, 2020 9:50 am
Try only connecting one sensor node to Adafruit IO. Does it publish data?
brubell
by Ewbroberg on Fri May 01, 2020 11:01 am
Thank you for your reply.
I tried that as well. I have the same result. It is so weird because they were working and then just stopped. I also tried removing the feed and creating a new one with the same name, and different name. Same results.
Erik
Ewbroberg
by brubell on Mon May 04, 2020 9:34 am
Are you able to publish to the default feed?
brubell
by Ewbroberg on Mon May 04, 2020 1:26 pm
I have it working now. It rebuilt my entire .ino file by copying chunks and pasting them into a new project. I am using Visual Studio and I think there is some corruption when building a project that can happen. I had a script that failed in one project but worked when copied and pasted into another project. I seems to be related to the includes. I am not sure entirely what is going on but it now works.
Thank you,
Erik
Ewbroberg
