MQTT > Adafruit IO > IFTTT > Twitter delays
by Systembolaget on Sun May 10, 2020 5:50 pm
1. When wanting to tweet if a button was pressed, a door was opened or some other one-shot action occurred, the timing is off, as shown in the screenshots below. I made sure that after publishing a 1 (pressed, opened, etc.) immediately a 0 is published so as to trigger only a one-shot event. IFTTT unfortunately does not reveal how frequently it watches an Adafruit IO topic. Are these sometimes up to 20 minutes long delays between a value registered at the Adafruit IO feed and the corresponding tweet appearing in the Twitter timeline normal? Is there an Adafruit IO or IFTTT limit? Is there a way around the delay?
Skärmbild 14.42.31.png (537.16 KiB) Viewed 136 times
Skärmbild 18.45.09.png (115.18 KiB) Viewed 136 times
2. The IFTTT > Twitter applet fails, if the tweets are identical. One can include a timestamp in the applet to make each tweet unique.
Skärmbild 15.22.09.png (53.16 KiB) Viewed 136 times
Systembolaget
Re: MQTT > Adafruit IO > IFTTT > Twitter delays
by brubell on Tue May 12, 2020 10:38 am
Unfortunately the delay is on IFTTT's side, not IO. IFTTT integrations may take around 15-20 minutes to trigger.
You may also want to try Zapier instead of IFTTT, it's a similar platform and may have a shorter delay. We have a guide about using IO with Zapier here: https://learn.adafruit.com/using-zapier ... dafruit-io
brubell
by LagomBra on Tue May 12, 2020 3:26 pm
Yeah, well... just gave Zapier a try. Looks neat, but AIO > IFTTT > Twitter response time is 5 to 17 minutes, while AIO > Zapier > Twitter response time is 15 minutes minimum as per Zapier's $0 and $19.99 per month plans. I pitched IFTTT against Zapier and IFTTT won by 7 minutes, quite a difference. For true near-real-time alerts, SMS is probably the better option.
Also, IFTTT is happy tweeting away, while Zapier's free tier has a 100 tasks per month (e. g. tweets) limit, and then Zapier stopped after the first tweet because it says Twitter blocks duplicate tweets. The timestamp added prevents this reliably via IFTTT but not via Zapier, so it seems.
Skärmbild 20.59.35.png (148.7 KiB) Viewed 132 times
In that sense, IFTTT is better, also because if Zapier checks only every 15 minutes, it will surely catch a value of 0 after a button was pressed, a door was opened or some other one-shot action occurred.
For our academic projects, I am ok with spending $99 for AIO and maybe, just maybe, $199 for IFTTT, in case one gets a better response time with the IFTTT developer account instead of the free tier. There's no information on that. I have to ask, I guess.
LagomBra
by Systembolaget on Wed May 27, 2020 1:21 pm
Problem with Zapier > Twitter is that, for some reason, adding a timestamp to a tweet still invokes the "duplicate tweet" error, so even if one expects a message seldomly, only the first one will ever arrive. IFTTT > Twitter with added timestamp works.
Or does someone know a workaround for Zapier?
Systembolaget
by brubell on Fri May 29, 2020 10:15 am
Are you able to add a timestamp to the twitter text within the zapier workflow builder?
brubell
by Systembolaget on Fri May 29, 2020 10:30 am
Yeah, but Twitter somehow doesn't respect that, while it does so with the one added in IFTTT.
Systembolaget
by brubell on Fri May 29, 2020 10:44 am
Systembolaget wrote:Yeah, but Twitter somehow doesn't respect that, while it does so with the one added in IFTTT.
Strange, I personally only use zapier to tweet and haven't hit that issue.
You may want to check...
Before posting updates to Twitter, a Zap will first check that the same post hasn't been made by any Zaps under the same Zapier user's account. The error message means that the same status was posted by either the same Zap or another Zap. Twitter has strict policies on automation and the use of multiple accounts
via https://zapier.com/help/doc/common-problems-twitter
brubell
by Systembolaget on Fri May 29, 2020 7:05 pm
What I did.
Skärmbild 00.50.48.png (85.56 KiB) Viewed 114 times
What I should do instead?
Skärmbild 00.51.38.png (223.72 KiB) Viewed 114 times
Is the second way the one you do it to avoid duplicate tweets? First way is only a static timestamp at Zap creation time?
By the way, what about Zapier's free plan (every 15 minutes) polling of an Adafruit IO feed, wouldn't that miss an event that triggers a 1 and immediately after a 0 - a "one shot" action, like a button pressed or a window smashed?
Systembolaget
by Systembolaget on Sun May 31, 2020 12:03 pm
Too bad, also a proper timestamp results in Zapier stopping the Zap from tweeting the same notification more than once.
"Your Zap named Create tweet in Twitter when get feed data in Adafruit IO was just stopped. This happened because our systems detected this Zap posted a duplicate tweet, which is against Twitter's Terms Of Service."
How did you manage to get it working?
Systembolaget
by Systembolaget on Wed Jun 03, 2020 1:51 pm
Could you maybe share the way you managed Zapier to tweet "Rear door opened" more than once? Even with a timestamp, it is flagged as duplicate tweet, unlike via IFTTT.
Systembolaget
by brubell on Fri Jun 05, 2020 9:58 am
To clarify, I meant that I only use Zapier to tweet about IO library releases which are unique. I use IFTTT for most things.
I'm going to email Zapier's support about this issue, though and follow-up with you.
brubell
by Systembolaget on Fri Jun 05, 2020 3:05 pm
Thanks, that would be great. I have testet this extensively for several weeks and my findings are:
AIO feed > IFTTT + timestamp = tweet with same alert message always arrives at my feed in 6 - 37 minutes
AIO feed > Zapier + timestamp = tweet with same alert message arrives only once after 15 minutes and then blocked
Systembolaget
by brubell on Tue Jun 09, 2020 11:38 am
Ok, got a response back from Zapier's partner support:
Before posting updates to Twitter, a Zap will first check that the same post hasn't been made by any Zaps under the same Zapier user's account. The error message means that the same status was posted by either the same Zap or another Zap. Twitter has strict policies on automation and the use of multiple accounts as detailed in this post.
It sounds like our automated checks here are catching these tweet actions since they're in violation of Twitter's terms of service.
If the error message is still occurring, Zapier pointed me to the customer support form: https://zapier.com/app/get-help. Please file a bug over there to possibly have your workflow tightened up so they meet ToS, or Zapier can log a bug report from their end.
brubell
by Systembolaget on Tue Jun 09, 2020 12:25 pm
Yeah, it still occurs. I do as you suggest. Thanks!
Systembolaget
cron
